driver side rear mirror moves?
wondering if any of you guys have this problem? when you go to unlock your car, does your driverside mirror start to move slightly? it moves like 4-5 directions and stops. dunno if i should get this looked at.
mirror settings are part of the presets, along with the seats and steering wheel. Is someone else (another smart key) driving or getting near the car between your using it? That would cause the car to adjust to them and then back to you (moving the mirrors, etc.)
I wasn't even aware that different smart keys held different driver presets?
Is this something that was added later than the first GS3 model year? I don't recall any mention of this in the owners manual at all. My wife drives the car sometimes and is a good foot shorter than me which necessitates pressing the driver buttons... I've been keeping the spare key in a safe place and we've been sharing the same key just because I didn't think there was any link between the key and driving presets on this car like some others.
Something about holding the key button and the preset key at the same time to set. So it go by the key and change the setting accordingly.
I think the loop hole / problem is the car don't know which key is in the driver seat. So if U drive, U better unlock and get in first so it uses your setting and not your wife's setting.
This is from the FSM
Memory Call Registration Function
• When the driver presses the key lock or unlock button while pressing memory switch [1] (or [2], or [3]) with the engine switch pressed OFF and the driver's door closed (driver's door courtesy light switch OFF), the system will assign the ID of the key, which is used for this operation, to the corresponding memory switch.
Memory Call Registration Cancel Function
• When the driver presses the key lock or unlock button while pressing memory switch [SET] with the engine switch pressed OFF and the driver's door closed (driver's door courtesy light switch OFF), the system will cancel the ID of the key, which is used for this operation, in the memory call registration.
no one else drives my car and i only use one smart key. other smart key is stored away.
