Weird shudder when slowing, help!
Old Nov 18, 2009 | 07:50 AM
gridlock13's Avatar
gridlock13
Default Weird shudder when slowing, help!
I was slowing down for a red light today when the car shuddered for a second. it's happened once before. the car was already running for about 20 mins and the engine temp read normal. it was 45 degrees out and i have no modifications at all. what could be the problem?
Old Nov 18, 2009 | 08:39 AM
rominl's Avatar
rominl
exclusive matchup
maybe have the dealership check the throttle body and make sure it's clean?
Old Nov 18, 2009 | 09:56 AM
BinaryJay's Avatar
BinaryJay
Did you notice anything weird happening on your tach when it shuddered? Did it suddenly dip into very low rpm range? The shuddering can be from one of your brakes seizing, the engine nearly stalling (low rpm), or any number of things I suppose.
Old Nov 18, 2009 | 10:15 AM
raytay's Avatar
raytay
I had that happen to my car also, the dealer checked it out and couldn't find anything wrong. They recommended to change the place I buy gas as it may be inferior. Let me know if you find anything.
Old Nov 18, 2009 | 11:49 AM
I8ABMR's Avatar
I8ABMR
Have the dealership check it. It sounds like a intake/fuel issue. These cars can hicup from time to time. I remember when I first got mine and I would push to red line and the car would tap the limiter before it shifted. Its happened twice but nothing since then
Old Nov 18, 2009 | 01:49 PM
gridlock13's Avatar
gridlock13
i did notice the RPM was around 500 but usually this happens when i come to a full stop. the car was still rolling. i filled up with BP gas. i don't remember which type of gas i filled up with the first time it happened. i'm afraid to call the dealership since my car is out of warranty but we'll see.
Old Nov 18, 2009 | 02:14 PM
scorpio74's Avatar
scorpio74
Make sure you put gas in the car from the same station as often as possible. Mixing gas stations can cause this problem. I personally like Shell.
Old Nov 18, 2009 | 03:54 PM
EyeKutr's Avatar
EyeKutr
I have had family members in the gas delivery business in the past, gas is gas. Mixing stations will not do jack. Arco gas is same as other gas. The chevron gas with techroline is like a huge 60,000 gallon tank and they dump in like a quart of additive. Octane grading can cause this, not brand or station variation.
Old Nov 18, 2009 | 06:46 PM
I8ABMR's Avatar
I8ABMR
I would recommend adding a bottle of octane booster. Check the manual though.
Old Nov 19, 2009 | 12:06 PM
MadDawg350's Avatar
MadDawg350
Please clarify what you mean by "shuddered." Did you feel this coming through the brake pedal while you were applying the brakes or was it the engine that "shuddered" while slowing down. If you felt it coming through the brakes, you likely have warped rotors. If it was the engine, my guess is that the tranny did not downshift while the car was slowing down, and this caused the engine rpm's to drop to the point that you felt the shuddering, almost stalling like BinaryJay stated.
Old Nov 19, 2009 | 02:07 PM
gridlock13's Avatar
gridlock13
it didn't come from the brake pedal cuz if it did i'd feel a gradual shudder wouldn't i? it was just for a second. if it is the transmission, what's the solution?
Old Nov 20, 2009 | 06:38 AM
BinaryJay's Avatar
BinaryJay
If you can't make it happen consistently then there isn't really one. If you can, then your transmission should still be under warranty no?
Old Nov 20, 2009 | 09:42 AM
gridlock13's Avatar
gridlock13
luckily it's only happened twice in the 9-10 months i've had the car. it's just that the two times it has happened was just a few days ago and then maybe a month ago. this forum has so many knowledgeable members that i was looking for some insight about if this is a major problem that will get worse over time. i'm just over 71,000 miles on my car so yeah it should be under warranty. thank you everyone for your input!
Old Nov 22, 2009 | 08:35 PM
blckwidow's Avatar
blckwidow
My car occasionally does the same thing when I'm sitting idle, in reverse, or slowing down. I took it to the dealership and they couldn't find anything wrong. They told me to try and do a fuel injector cleaner. Still no luck. Let me know if anyone finds out anything.
Old Nov 27, 2009 | 04:49 PM
slk_dds's Avatar
slk_dds
Just noticed the "SHUDDER" today, I am going to bring it in tomorrow to see what the heck is going on...
