Rain Sensitive Wipers
Old Oct 28, 2009 | 10:28 AM
seattlegs's Avatar
seattlegs
Default Rain Sensitive Wipers
I've noticed when the wipers are set to auto & at the highest sensitivity, they don't come on frequent enough. There's plenty of rain on the windshield but the wipers don't come on quick enough. I'm gonna take in to have Lexus take a look at it but wanted to see if anyone has any feedback.
Old Oct 28, 2009 | 10:46 AM
vuiskool's Avatar
vuiskool
Which way did u have it turned?
Old Oct 28, 2009 | 10:54 AM
seattlegs's Avatar
seattlegs
The sensitivity **** was turned towards me, down to the + sign.
Old Oct 28, 2009 | 11:30 AM
BinaryJay's Avatar
BinaryJay
Locate where the sensor is, and check to see if it's clogged up with dirt or car wax?
Old Oct 28, 2009 | 11:58 AM
seattlegs's Avatar
seattlegs
Any idea where the sensor is?
Old Oct 28, 2009 | 12:03 PM
tcr101's Avatar
tcr101
if i remember correctly, the sensor should be at the top near the mirror, should be a panel you can see from the outside
never had trouble with my wipers, but usually wipe down the windshield before i drive
Old Oct 28, 2009 | 12:27 PM
rominl's Avatar
rominl
exclusive matchup
yes, you can see frmo outside, area where the rear view mirror is "stuck" to the windshield
fwiw, i am never a fan of the stock sensor system neither. it's never really accurate. when i want it fast, it doesn't work. when i want it slow, light drizzle triggers it
my bmw works far better
Old Oct 28, 2009 | 12:30 PM
BinaryJay's Avatar
BinaryJay
Interesting tidbit mined out of google about how they work that could give you some clues about why yours aren't responding well:
The technology behind rain-sensing wipers is not complicated. A small area of the front windshield glass (usually located on the outside of the vehicle, opposite the rear-view mirror) is monitored by an optical sensor. The sensor is designed to project harmless infrared light at the windshield at an angle and then read the amount of light that is reflected back. A clean windshield will reflect nearly all of the light back, while a wet or dirty windshield will cause the light to scatter. The optical sensor can determine the necessary frequency and speed of the windshield wipers by monitoring the amount of light reflected back into the sensor.
Old Oct 28, 2009 | 01:07 PM
Yang1815's Avatar
Yang1815
Might make more sense to have two sensors and take the average. That may help with the windshield wiper frequency accuracy.
Old Oct 28, 2009 | 01:13 PM
The G Man's Avatar
The G Man
The rain sensor not only senses rain, it is speed depended as well. If you are at a red light, it will slow down or stop, if you are on the highway, it will go faster.
Old Oct 28, 2009 | 04:24 PM
codraw's Avatar
codraw
thanks for the info, that's good to know it's speed depended.
Old Oct 29, 2009 | 08:33 AM
Lexzam's Avatar
Lexzam
Interesting. I always thought the sensors are based on conductivity, which changes with wet surface. There actually seems to be two different technologies: electrical conductivity sensor and the infrared optical sensor. Does anyone know which one Lexus is using?
See below description of the other conductivity sensor:
" The rain sensor system comprises first and second electrical conductors spaced uniformly from one another and an electrical insulator interposed therebetween. A dual network voltage divider circuit couples the first conductor to an applied reference DC voltage level, and the second conductor is coupled to ground potential via a similar network. Airborne raindrops and moisture temporarily adhere to the exposed surfaces of the insulator to electrically couple the exposed surfaces of the first and second conductive surfaces to lower the electrical resistance therebetween. The magnitude of the applied voltage changes in relation to the intensity of rainfall or amount of raindrops adhering to the conductors to affect the rate of windshield wiper action. An rpm speed linearizing circuit may also be employed to compensate the rate of windshield wiper action in response to vehicle speed. The conductor has an elongated shape for providing self-clearing of raindrops or moisture from the sensor. "
Old Oct 29, 2009 | 11:17 AM
The G Man's Avatar
The G Man
Lexus use the infrared type. The conductivity type would only work if the two conductors are outside the windshield. I dont think any manufacturer us the conductivity type.
Old Oct 29, 2009 | 02:07 PM
kyang91's Avatar
kyang91
I have the similar problem from time to times.
Old Oct 29, 2009 | 02:45 PM
I8ABMR's Avatar
I8ABMR
I have noticed the same thing with my car. I will driving with the windshield covered and no wipers. I think it waits until visibility is mildly affected then it turns on. It wont turn on for a few droplets
