Odd Brake Behavior
Old Aug 29, 2009 | 08:58 AM
Bushwack's Avatar
Bushwack
Default Odd Brake Behavior
With 17,000 miles and the 'dustless' pads installed, the car's brakes will squeal for the first couple applications (after the car has been sitting a couple hours). Thereafter, the squealing stops (the brakes perform well). It seems as the brakes heat up, the squealing stops. With two past Toyota's (a 1981 Celica and a 1985 Cressida), just the opposite would occur. Once the pads heated up, the squealing would begin.
Anyone else have similar behavior?
Old Aug 29, 2009 | 04:57 PM
Rider's Avatar
Rider
I have the same problem! A brand new car with brakes squeaking as soon as I operate the car! Weird
Old Aug 30, 2009 | 09:59 PM
XxGoKoUxX's Avatar
XxGoKoUxX
i'm not 100% on this, but if you leave it outside, or in a place with plenty-o-moisture.... the brake discs will rust up, so i would figure that's where teh squeeling comes from
Old Aug 31, 2009 | 10:07 AM
ward565's Avatar
ward565
i have the same problem >>> I did the impossibles without benifit ...
Old Sep 2, 2009 | 07:35 AM
slk_dds's Avatar
slk_dds
Guys, this might help you out!!!
The one that is currently on my toy is TSIB L-SB-0121-08;
https://www.clublexus.com/forums/gs-...-brakes-2.html
Also Andy (Yang1815) found TSIB 0040-09, that would also replace the rotors.
Good luck,
Steve
Old Sep 2, 2009 | 07:38 AM
Yang1815's Avatar
Yang1815
Good luck,
Steve
Yeah they replaced the rotors and brakepads on mine.
supra725
Jan 27, 2016 11:12 PM
shivam
May 23, 2013 04:39 AM
adhana2
Feb 15, 2009 10:38 AM
gsowner88
GS - 1st Gen (1993-1997)
Aug 29, 2007 10:44 AM
nysupraman
Jun 22, 2003 03:10 PM
