back to dust-brakes!
Old May 12, 2009 | 09:11 AM
Yang1815's Avatar
Yang1815
Why can't we get a nice compromise >_<
Mine are dustless and they squeak too...
Old May 12, 2009 | 10:28 AM
GS300.ru's Avatar
GS300.ru
Give Posi Quiet a try, superb performans and very low dust
Old May 12, 2009 | 01:20 PM
slk_dds's Avatar
slk_dds
I had all three types of pads on my toy: C>>>A>>B
A = HIGH-FRICTION-SUPER-DUSTER- if you like to bend-over daily, this is what you want!!!
B = DUST-FREE-SQUEALER - when braking, it feels like two slick stone grinding; did not feel safe when traveling at high speed, because not sure if it would stop in time.
C = SQUEAK-FREE-LOW-DUST - best of both world nearly no dust build-up, with closely matched performance of super-duster!!!
-Performance: A=100% / B=65~70% / C=85~95%, when comparing to each other;
-Dust: A=100% / B=5% / C=5~15%;
-Suealing: A=0% / B=90~95% / C=0%.
Personally I would recommend SQUEAK-FREE-LOW-DUST (currently wearing), just because I do like to keep my toy clean whenever is possible. With SQUEAK-FREE-LOW-DUST, dust build up in 6~8 weeks equals to 1~2 days from HIGH-FRICTION-SUPER-DUSTER!!!
Old May 12, 2009 | 05:55 PM
Yang1815's Avatar
Yang1815
Originally Posted by whlkev
are you saying that bmw doesn't know how to make brake pads too
the dust problem is a lot worse...
I agree. I've seen many 3 series running around with black front wheels and silver rear wheels.
Thanks slk_dds!!!
Old May 13, 2009 | 06:33 PM
twister's Avatar
twister
doc, if A/B/C are what you've experienced, than mine is D: SQUEAK-FREE-SUPER-DUSTER. Supposed to be the latest kit
Old May 14, 2009 | 07:40 AM
JPF's Avatar
JPF
slk_dds, I have been looking at aftermarket brake pads for my 2008 GS350 and I've been having a hard time finding some that I am confident they will work without squeaking. Sounds like your SQUEAK-FREE-LOW-DUST pad are probably aftermarket pads. Would you mind telling me which brake pads you are using?
Thanks,
Old May 14, 2009 | 09:48 AM
Stormforge's Avatar
Stormforge
executive matchup
Thanks,
you can get endless m-sport or hawk hps brake pads for our GS...they are low dust.
Old May 14, 2009 | 04:09 PM
Cut-Throat's Avatar
Cut-Throat
Veteran: Navy
Yup, I just called the dealer today.
1.) I first had dusty brakes.
2.) took it in and the TSB had them replaced with the Dust-free brakes.
3.) They started sqeeking like a banshee after 6 months.
4.) took it in for the Squeek TSB.
5.) Dusted up just like my orginals.
6.) Called the dealer and he says "We have a fix for that" --
With any luck, I'll never have to pay for new brakes for this car!!
Old May 15, 2009 | 08:15 AM
twister's Avatar
twister
yep, almost 40k on mine with new “complimentary” brakes Another good freebie trick, considering I've been getting all of my oil changes for free (the last one will be at 40k) is to open Lexus VISA. I put max deposit using it on both of my early ES350 and than GS350 replacement - you get enough Lexus credit points to last you for a ton of free oil changes
Old May 16, 2009 | 12:10 PM
osokuko's Avatar
osokuko
What about the rotors, when going back to the dust pads?
Old Sep 2, 2009 | 07:31 AM
slk_dds's Avatar
slk_dds
Thanks,
Sorry guys, did not see this till just now...
But here is the TSIB for "C": TSIB L-SB-0121-08;
Also Yang1815 has a new TSIB that would also replace the rotors: TSIB 0040-09.
Old Sep 2, 2009 | 07:54 AM
tunedis95's Avatar
tunedis95
I love my dusty brakes!!! Adds that rough look to the car. ha ha. I'm on my second set already. I don't dare to even try dustless pads and sacrifice performance.
Old Sep 2, 2009 | 08:39 AM
EyeKutr's Avatar
EyeKutr
I think you guys should all go back and get the smaller calipers from the 06 gs300....the pads never squeal, grip fine and there is no brake dust.....the brake service also does not have to involve changing out the rotors as may be the case in the gs350/430/460 ...
Old Sep 2, 2009 | 03:36 PM
BKE420's Avatar
BKE420
i was tired of dealing with the dealer with my squealing brakes. i purchased the endless sss(super street sports). experienced a little squeak a couple of times. not a high pitched squeal. nothing in comparison to the latest tsib done. brake dust is non existent. no worries with the braking ability.
ISFHEMS
Suspension and Brakes
14
Feb 12, 2015 04:39 PM
Amalan
Jun 9, 2009 01:27 PM
1_alterdis
Feb 5, 2008 11:16 PM
Pineapple
Aug 18, 2007 07:48 PM
TeeLex
21
Aug 11, 2004 10:19 PM
