3GS wheel thread
Old Feb 16, 2015 | 11:07 PM
  #1576
tmf2004's Avatar
tmf2004
5% Club. Killing it!!!
definitely invest in a Torque Wrench... For our 2 Gen GS's they require 76ft lbs... not sure what the 3 GS is rated at but most shops if not all air power the lugs nuts on and they end up being over a 100ft lbs... Trying to loosen them after you get your car back from the shop is a PITA....
Old Feb 17, 2015 | 08:13 PM
  #1577
1UGLYGS's Avatar
1UGLYGS
teaser of my work in progress. 4 and 5.5 inch lips!
Old Feb 21, 2015 | 07:11 PM
  #1578
justYnG's Avatar
justYnG
Originally Posted by LexusLadi
This happened to me once. Well actually I snapped the entire bolt off lug still attached. I had a set of wheel spacers and ended up removing all of them due to me not trusting the build quality...
I have two words for you: TORQUE WRENCH!
torque wrench was ordered and received! i have a digital torque wrench but the batteries are dead (and keep dying) and i really dont trust it all the way. so the newest addition is my mechanical torque wrench! i work at the tundra/tacoma plant in texas. the stock aluminum lugs that comes with the gs are identical to the ones we use on the tacoma. the target torque is 125NM, but this is on a truck and im not sure if they share the same studs.
Old Feb 23, 2015 | 04:41 AM
  #1579
uberEJ's Avatar
uberEJ
wheel/tire specs?
its 76ft lbs. for the 3gs as well.
i always torque mine to around 85-90 on all the cars ive had. everytime i try to torque it in the 70's the lugnuts come loose. so i have been doing 85-90 with no problems.
Old Feb 23, 2015 | 05:07 AM
  #1580
tmf2004's Avatar
tmf2004
any digital torque wrench recommendations? or stick to the manual type? thanks
Old Feb 23, 2015 | 08:17 AM
  #1581
uberEJ's Avatar
uberEJ
stick to the manual type. i dont really trust the electrical ones. and just an FYI all torque wrenches need recalibration after awhile. i get it done every year.
Old Feb 23, 2015 | 07:34 PM
  #1582
justYnG's Avatar
justYnG
stick with manual unless youre getting a high digital wrench. the ones at my work are no joke and cost minimum of $2k a piece, but thats a whole other story. the digital wrench i have is a brownline digital wrench and i a tektra manual torque wrench. both can be found at amazon
Old Feb 23, 2015 | 08:23 PM
  #1583
tmf2004's Avatar
tmf2004
I just bought 1/2" drive torque wrench from Harbor freight and the the instructions say recalibrate every 6 months. where do they get re calibrated at? I have the larger 3/8 drive as well. both manual versions
Old Feb 24, 2015 | 04:29 AM
  #1584
justYnG's Avatar
justYnG
I wouldn't rely on there torque wrenches. This is what I got
TEKTON 24335 1/2-Inch Drive Click Torque Wrench, 10-150-Foot/Pound https://www.amazon.com/dp/B00C5ZL0RU/ref=cm_sw_r_awd_O6g7ub1EJHQ0E
Old Feb 25, 2015 | 12:25 PM
  #1585
uberEJ's Avatar
uberEJ
i just give it to the snap on truck guy that goes to my Stepdad's shop and he gives it back the next time he comes around... usually under a week.
just after every use, return it to the lowest setting to make the calibration last as long as possible. i dont use it that often to have to get it re calibrated every 6 months. however i do have a smaller torque wrench both ft/lb and in/lb that i give to the snap-on guy every 3 months cus i use it for everything when i have the torque specs.
i agree with justyng about the reliability of harbor freights. i compared it to the snap-on one i got and it runs off every so often. like i was getting +5lbs one time then tested at another weight i was getting like -10lbs... but this is using the harbor frieght one for awhile. but, you need to get that recalibrated im sure if you take it to harbor freight they will probably just give you a new one lol.
Old Mar 3, 2015 | 05:32 PM
  #1586
1UGLYGS's Avatar
1UGLYGS
Old Mar 3, 2015 | 06:26 PM
  #1587
SoCal_450h's Avatar
SoCal_450h
is this another teaser???,....we need to see side view...LOL
she looks really hot...
Old Mar 3, 2015 | 06:31 PM
  #1588
tmf2004's Avatar
tmf2004
great pic... looks awesome..
Old Mar 4, 2015 | 09:18 AM
  #1589
LexusLadi's Avatar
LexusLadi
Nice Ride!
Airbags, right?
Old Mar 4, 2015 | 11:00 AM
  #1590
uberEJ's Avatar
uberEJ
wheel/tire specs though?
