Cam Gears Replaced
CL Members:
Upon hearing rattling (sounded like valvetrain noise) noises when starting the car in the morning took it in for warranty work.
Amazingly enough the dealer was able to duplicate the noise and therefore are replacing both Cam Gears under warrant.
Definitely a big job and thankfully i will not incur an expense over this repair.
The dealer hear in Las Vegas has always been top notch when it comes to warranty issues and it was no different with this experience.
Just a fyi for all this that are experiencing this same issue.
Good luck
Good luck
When I pull up to a drive through and the sound echoes off the wall, I can hear a ticking from the engine, which I attributed to the direct injection system. It is quiet inside the cabin, but when I open the window I can definitely hear ticking. I plan on asking the dealership to look into it when I get back from the "stan"
all GS's tick like that.
As "dunnojack" says, they all does it.... You can call me ray, or you can call me jay, or you can call me.....
L
The engine purposely uses direct injection as much as possible when idling or driving in order to heat up the exhaust system to the right temperature. That is part of why it is certified as ULEV II. So you will hear it more when the engine is cold. I find the noise normal considering it does this. Never have experienced the rattle though...
EthanV
Mar 2, 2014 11:37 AM
