Manual Mode?
Old Jun 3, 2009 | 08:56 PM
Leonard15's Avatar
Leonard15
Default Manual Mode?
Hi guys is there a way to make your manual mode not automatically go to 4th gear whenever you switch over to it from automatic mode?
Also sometimes when I down shift I have to shift it a few times for it to go from second gear to first gear. Anyone else have that issue?
Old Jun 3, 2009 | 09:12 PM
ivanz's Avatar
ivanz
Are you below the maximum speed for shifting from 2->1? You can only shift after you slow down to a certain speed (can't recall it ATM).
Old Jun 3, 2009 | 10:50 PM
rominl's Avatar
rominl
exclusive matchup
it doesn't always go to 4, it depends on your speed i believe. but if you are over certain cruising speed, putting it in manual and it will default into 4. don't think you can change that
for the 2nd to 1st (or any other downshift), you have to be below certain speed for each gear otherwise the computer won't allow you (or it will rev up too high)
Old Jun 4, 2009 | 07:46 AM
Leonard15's Avatar
Leonard15
It doesn't matter on my speed as even if I am stopped and I shift over to manual it says 4th. I guess that makes sense about going from 2 to 1 as sometimes I tend to slow down really slow and try to downshift so I can lay off on the brake as it slows down really fast and saves your breaks.
Old Jun 4, 2009 | 10:21 AM
copa's Avatar
copa
I have the same problem. This is now how my last car worked.
Old Jun 4, 2009 | 10:50 AM
rominl's Avatar
rominl
exclusive matchup
really, umm, gotta try it out again. if that's the case i guess it's working different from the 8 speed on 460
Old Jun 4, 2009 | 12:58 PM
The G Man's Avatar
The G Man
Must be a nightmare trying to manually shift 8 speed
Old Jun 4, 2009 | 01:22 PM
IXI187IXI's Avatar
IXI187IXI
mine is the same way execpt mine always starts in 5 even when im stopped.
Old Jun 4, 2009 | 02:50 PM
Leeladisky's Avatar
Leeladisky
Is anyone driving in manual, full-time? Do you have a 350 or 460?
Lee
Old Jun 4, 2009 | 03:34 PM
coreyco's Avatar
coreyco
Would any wear and tear on the transmission caused by downshifting be offset by the savings on less use of the brakes?
Old Jun 4, 2009 | 03:37 PM
rominl's Avatar
rominl
exclusive matchup
that's why after a few tries just to be cool, my ls460l always stayed in D
Lee
almost always in D, if anything i mostly go to S when i am on freeway and want to slow down the car without braking (ie, cops from behind).
Old Jun 5, 2009 | 10:12 AM
rominl's Avatar
rominl
exclusive matchup
Originally Posted by moar_power
kinda like driving a Peterbilt at that point. Does anyone think that Lex/BMW/MB/Audi will come out with 9 or 10 speed transmissions? Or have we reached 'peak gearbox' so to speak.
i think at 8 gears we have reached the limit of diminishing returns. Or maybe we'll get CVT like the 450H.
having driven the 8 speed, it's a lot of gears and indeed quite a bit of shifting specially at lower speed, but i think lexus has done a pretty good job in that. next step though should just be cvt
Old Jun 8, 2009 | 10:36 AM
Just a Guy's Avatar
Just a Guy
I drive around town in manual in my 460 quite a bit. I find that I don't normally shift higher than 4th or 5th, so the 8 gear transmission isn't too big a deal for me.
Old Jun 8, 2009 | 03:16 PM
dunnojack's Avatar
dunnojack
kinda like driving a Peterbilt at that poin.
hah. that thing has like 16 gears right?
row row row your boat..................
HOMER350
Jul 21, 2018 11:05 PM
propcop
Jun 29, 2015 12:16 PM
tofu
Aug 9, 2013 06:57 AM
pemarsh
LX - 3rd Gen (2008-2021)
25
May 19, 2008 09:16 AM
alsilverbullet
Jul 12, 2003 06:15 PM
