Drilled/Slotted OEM Sized Rotors?
Rotora does offer slotted, and drilled/slotted OEM size rotors for the 3rd Gen GS. You can download their 2008 internet catalog when you go to www.rotora.com
For the lazy peeps here, I'll list them out for you:
2006 GS300
Basic OEM:
FL (part #R44140), FR (part #R44139)
RL (part #R44141), RR (part #R44141)
Slotted:
FL (part #R44140.1S), FR (part #R44140.2S)
RL (part #R44141.1S), RR (part #R44141.2S)
Drilled & Slotted:
FL (part #R44140.1C), FR (part #R44140.2C)
RL (part #R44141.1C), RR (part #R44141.2C)
2006 GS430
Basic OEM:
FL (part #R44138), FR (part #R44137)
Slotted:
FL (part #R44138.1S), FR (part #R44138.2S)
Drilled & Slotted:
FL (part #R44138.1C), FR (part #R44138.2C)
2007 GS350 (2WD) & GS430
same as 2006 GS430 above
2007 GS350 (AWD)
Basic OEM:
FL (part #R44154), FR (part #R44155)
Slotted:
FL (part #R44154.1S), FR (part #R44154.2S)
Drilled & Slotted:
FL (part #R44154.1C), FR (part #R44154.2C)
2007 GS450h (hybrid)
Basic OEM:
Slotted:
Drilled & Slotted:
Hope this helps!
2006 GS300
Basic OEM:
Slotted:
Drilled & Slotted:
2006 GS430
Basic OEM:
Slotted:
Drilled & Slotted:
2007 GS350 (AWD)
Basic OEM:
Slotted:
Drilled & Slotted:
Basic OEM:
Slotted:
Drilled & Slotted:
Hope this helps!
That is only true for racing cars. How much racing are you doing in your GS? Slotted rotors might be better in the long term due to less tendency to warp (due to better heat dissipation). But drilled rotors are actually way worse than solid Lexus OEM rotors because they tend to crack quite frequently.
Last edited by DaveGS4; May 19, 2008 at 06:32 AM. Reason: removed inanappropriate language
i can't say for sure about lexus parts, but all i know is, lexus oem parts are super expensive
OEM ones for my bmw were about 600 bucks, I got the brembo replacement rotors for 450
and those cross drilled critics, do you even have personal experience with them? to say they crack under extreme heat is like saying your car will stall if you don't warm up. Manufacturing techniques have gone way up and every single exotic cars with cross drilled rotors are going to crack ... right..
^ finally a objective opinion.
When I say "Drilled and slotted rotors do help dissipating heat quicker therefore improve the braking performance." simply based on the fact (or the goal to achieve by the manufacture). I did not say that they are better than Lexus OEM's nor they won't crack.
^ finally a objective opinion.When I say "Drilled and slotted rotors do help dissipating heat quicker therefore improve the braking performance." simply based on the fact (or the goal to achieve by the manufacture). I did not say that they are better than Lexus OEM's nor they won't crack.
