high beam
Old May 2, 2008 | 04:05 PM
smokeganja's Avatar
smokeganja
Default high beam
i just change my high beam to a bright blue halogen bulbs...i was disapointed...the color seems to be a bit yellow...but when i switch it to my high beam high beam ...it turn out super white...the way i want it to be...what kind of halogen bulb should i use if i want my parking lights to turn out really blue & bright beside hid..????? thankzzz
smokeganja's Avatar
smokeganja
Default bright blue halogen
i just change my high beam to a bright blue halogen bulbs...i was disapointed...the color seems to be a bit yellow...but when i switch it to my high beam...it turn out super white...the way i want it to be...what kind of halogen bulb should i use if i want my parking lights to turn out really blue & bright beside hid..????? thankzzz
Old May 2, 2008 | 04:21 PM
EyeKutr's Avatar
EyeKutr
It wont work, because in the daytime, it is running at 1/2 voltage, so it will look yellowish no matter what, you can install a relay i guess, and basically get full voltage even in daytime running light mode but you will literally be driving with high beams on
Old May 2, 2008 | 04:26 PM
rominl's Avatar
rominl
exclusive matchup
correct, there is no way. you can put a 100w bulb in there so 1/2 the power and it's pretty darn bright white, but like eyekutr said you will be driving with highs on basically
not to mention about the heat and power. and when you really flip on the highs, you might see smoke
Old May 2, 2008 | 05:52 PM
smokeganja's Avatar
smokeganja
thankz guys...im thinking about putting hid now...
Old May 2, 2008 | 06:30 PM
rominl's Avatar
rominl
exclusive matchup
careful, i don't thnk you can just plug in hid kits and it will work. in fact, probably not coz' during the day it's 1/2 the power (voltage basically) so the hid might not even fire
if you put hid kits in highs, you will need to do more work
Old May 2, 2008 | 09:01 PM
SiccMonkey's Avatar
SiccMonkey
CL Folding 1,000,000
the only way to really eliminate it would be do have the dealer disable the DRL, that way it dont light up unless your high beams are on. other than that pretty much any bulb at 50% is going to look yellowish
Old May 2, 2008 | 10:33 PM
EyeKutr's Avatar
EyeKutr
HID would work fine if you run the power into a relay (which good HIDs have anyways) but again you will have HID on all day long AND you have no projector just a reflector....at night time when you turn on high beams, it will be glare city ......overall a BADD idea IMO, just drive with your headlights on, is there any difference if you think about it ?
Old May 2, 2008 | 11:05 PM
rominl's Avatar
rominl
exclusive matchup
plus you can pretty much forget about using the highs as "flash" coz' they won't flash fast enough
Old May 2, 2008 | 11:46 PM
kyang91's Avatar
kyang91
Yea I agree with all of them above, there is no way because it is hard to do that, just have the dealer disable the daytime running light and drive without DRL.
mikha619
Jan 1, 2013 12:18 PM
Meraki Autoworks
IS F (2008-2014)
Jul 31, 2012 02:07 PM
mugenh22a4
IS F (2008-2014)
Oct 31, 2010 12:22 PM
panda327
May 6, 2009 10:44 PM
bcdjad
Lighting
Nov 1, 2004 09:59 PM
