Mirror memory
Old Jul 10, 2007 | 04:51 PM
larrs's Avatar
larrs
Default Mirror memory
I've noticed lately that the outside mirrors don't return to the same position each time I push the memory button. I can sit there and push the button 3, 4, 5, 6 times and each time the mirrors move and stop at a slightly different position. I'm not sure if they've always been this way, or if this is something new.
Has anyone else noticed this? I'm wondering if there's a problem with my car, or if all of our cars are like this.
Thanks in advance.
Old Jul 10, 2007 | 06:39 PM
mel's-gs's Avatar
mel's-gs
I have noticed the same thing. They never go back to the same position when I use the memory. I find myself trying to work the little drop-down while I'm driving. Not a good idea.
Old Jul 11, 2007 | 02:01 AM
larrs's Avatar
larrs
It is frustrating.
Thanks for the reply.
Old Jul 11, 2007 | 07:09 AM
CsKWarEd's Avatar
CsKWarEd
I don't notice it with my mirrors but I do notice it with my seat. I've got to back it up all of the way, and the memory won't go all of the way back. I've reprogrammed it a few times but still same results.
Old Jul 11, 2007 | 03:58 PM
newflamenc's Avatar
newflamenc
Try this.. keep the driver door open until the seat is fully adjusted by the memory button. I noticed the seat would immediately stop adjusting once the driver door is closed.
Old Jul 11, 2007 | 05:35 PM
Yang1815's Avatar
Yang1815
It also doesn't start moving until you open the door.
I know cause I just stared at my seat from outside the car after I pressed "unlock" on the remote to see it moves
Old Jul 13, 2007 | 02:27 AM
larrs's Avatar
larrs
I usually hit the memory button with the door open before I get in if the seat has been moved. When I use the memory to reset the mirrors I'm already in the car with the door closed. It's usually because I had the mirrors folded and after they unfold they aren't set correctly. I've never tried opening or closing the door while the seat is moving. But when I hit the memory, the seat, if it moves at all, moves just once -- unlike the mirrors.
Old Jul 13, 2007 | 07:51 AM
zlee1's Avatar
zlee1
The mirrors are driving me nuts. here is what I figured out:
First I programmed my setting as slot # 1. My wife is slot # 2.
It is possible to program the remote (fob) to recognize the driver and automatically adjust the seat. I cleared out this function, for testing purposes. The instructions are in the manual (I think, with the engine off, hold the memory set button {not the slot button} and then the unlock on the remote). This did not resolve the problem.
I concluded that the problem is the auto tilt feature, when the car is in reverse. The mirrors are fine when I get into the car, but the driver's mirror gets messed up when I reverse out of my parking spot. So, I shut off the auto rear tilt, and the problem went away. The dealer has already replaced my passenger size mirror because it died, now I guess they will need to replace the driver's side mirror too.
Old Jul 13, 2007 | 08:50 AM
shel's Avatar
shel
If you have the mirrors folded will the remote unlock button unfold the mirrors while going thru an adjustment?
Old Jul 15, 2007 | 02:06 PM
larrs's Avatar
larrs
I don't use the reverse tilt feature, but I do fold the mirrors.
Old Jul 15, 2007 | 02:07 PM
larrs's Avatar
larrs
Not that I'm aware of.
Old Jul 16, 2007 | 08:32 AM
zlee1's Avatar
zlee1
I don't know either. I don't fold the mirrors.
drifter123
NX - 1st Gen (2015-2021)
13
Sep 14, 2021 05:38 AM
txjeff
IS C
Mar 6, 2014 06:37 AM
Alex818
Jun 6, 2013 05:22 PM
tex2670
Sep 5, 2011 11:17 PM
DagsIS350
Apr 12, 2006 06:34 AM
