I remember seeing a picture of a white 3GS with yellow high beam. I've been searching for that post but can't find it. If anyone has that please post a picture, thanks!
Considering putting yellow high beam bulbs in since the DRL's with any white bulb still appears yellow, might as well just make it real yellow.
I replaced with the "Xenon bulbs" on the high beam also tried to get raid of yellow DRL. During normal "high beam" operation it appeared xenon white, but during DRL operation it still appeared yellow.
In the owner's manual, it has the option to "TURN OFF DRL." So on my 5,000 miles service, I asked them to program DRL OFF. All they need to do is hooked up to the computer in the shop and program off.
Unless you still want DRL's function, you can replace the bulbs with LED bulbs. But you will loose the high beam's function, due to the fact that LED is not as bright as normal bulbs.
