Low beam Bulb recommendations?
Old Feb 7, 2024 | 10:12 PM
Druu's Avatar
Druu
Default Low beam Bulb recommendations?
Still have my Oem Bulbs in the low beam its just not bright anymore im gonna stick to 5000-6000k and i also want to change out that amber DRL to a white/blueish color. Any Brand recommendations?
Old Feb 11, 2024 | 11:28 PM
AJ3GS's Avatar
AJ3GS
Funny enough I did this exact thing. For the low beams, I switched to philips d4s 6000k ultinons. Had them for a few years now and they're still just as bright. For the high beams, which also double as the drls, I couldn't find bulbs that could handle the drl mode without flickering. But after some research, I came across the xenon depot 9005 bulbs with the pwm driver which could handle both the drl and high beam modes. I have also been using them for a while and they work perfectly. They do not flicker when they're being used as drls. These changes easily make the car look way newer than it is.
https://www.hidconcept.com/products/...hoCC9MQAvD_BwE
Amazon Amazon
Old Feb 12, 2024 | 12:31 AM
ibidu1's Avatar
ibidu1
How are your lenses on your headlights? Are they clear and polished? Or are they yellowed and foggy? Easy way to make your headlights brighter if they are cloudy, just polish them clear
Old Feb 12, 2024 | 01:19 AM
Druu's Avatar
Druu
https://www.amazon.com/9005-Xenon-De...ustomerReviews
yo thanks for the input ima look into that option. it is a bit pricey 200$+ just for some bulbs maybe when my tax refund come in. Heh.
yea they have been starting to yellow. i tend to buff the lens maybe once a month it does make a difference when i do buff the yellow haze out although its not 100% clear. i just notice how much brighter my girls newer 2017 Maxima's light output is and its no contest.
Old Feb 12, 2024 | 03:05 AM
AJ3GS's Avatar
AJ3GS
The bulbs are pricey but they will last. Once I tried cheaper hid bulbs on amazon and they didn't even fit. Also, some detailing shops may offer headlight restoration. IMO when I tried to buff the headlights myself, they didn't turn out very well. The detailer did a much better job.
Old Feb 13, 2024 | 06:57 AM
Carfan94's Avatar
Carfan94
I got the Osram Nightbreaker laser bulbs and they’re nice and bright. Keep the halogen DRLs. If you switch to LEDs you’ll loose your high beams. I did switch my parking light bulbs to 4000k LEDs to match the low beam HIDs. Looks nice at night having 4 white lights on the front of the car.
Old Feb 13, 2024 | 11:48 AM
AJ3GS's Avatar
AJ3GS
You could just stick to halogen high beams but the ones i put the link for which are leds have a resistor that works for both high beam and drls.
Old Feb 19, 2024 | 06:09 AM
Huezzy's Avatar
Huezzy
how bright are these? much better than OEM? I drive in really dark places and need to see very far ahead would they be good enough?
Old May 17, 2024 | 10:42 AM
Druu's Avatar
Druu
So i just purchased those Phillips d4s bulbs bkuz my passenger light keeps going out when im driving. I hope its just the bulb thats dying and not the ballast i hear the ballasts are a pain to replace. ill probably get those LED drl's on my next paycheck.
Old May 23, 2024 | 10:29 PM
energie8's Avatar
energie8
I've been using Garax 6000K for 5 years now.
Old May 24, 2024 | 08:15 AM
Druu's Avatar
Druu
yo so i just installed those philips d4s bulbs and i am amazed at the light output vs my old oem ones. i work nights so driving that late makes my drive enjoyable. exactly what i was going for. thanks agen. Next up im gonna get those DRLs. also was wondering if you changed out your oem fog light bulbs for something similar?
Old May 24, 2024 | 10:07 AM
AJ3GS's Avatar
AJ3GS
Glad to hear the lights are better than before. For the foglights, I can't remember exactly which ones I put in but on amazon I just looked up 9006 led fog light and just chose a model with good reviews. You want to make sure it's called 9006 fog light so it's not so bright. The non fog light ones can be very blinding
Cashflow1
RX - 3rd Gen (2010-2015)
22
Jan 3, 2023 07:06 PM
Frosty250
Oct 10, 2011 10:03 AM
en11871
Apr 5, 2008 12:51 AM
KNKGS400
Lighting
Oct 1, 2003 11:24 AM
GSman
Jun 26, 2001 01:44 PM
