Question about subwoofer replacement
Old Oct 10, 2023 | 12:13 PM
AJ3GS's Avatar
AJ3GS
No, I did not reuse the gasket, and I got the polk audio mm 1042 dvc. What I did was put some foam weather strips on the bottom of the subwoofer instead. I forgot to take pics, but in this photo you can see two of the four zipties. Again, I just routed them through the speaker screw holes and the holes where the 10mm bolts for the bracket went.
Old Oct 11, 2023 | 08:44 PM
doitup's Avatar
doitup
Looks good! How's the comparison?
Old Oct 11, 2023 | 08:46 PM
AJ3GS's Avatar
AJ3GS
Bass hits much stronger than before. Pairs very well with the ml speakers
Old Oct 12, 2023 | 02:02 PM
Oceans13's Avatar
Oceans13
I looked up the Polk sub and it appears to be 4 Ohm. If you have an Mark Levinson System, it needs to be 8 Ohm.
Old Oct 12, 2023 | 02:13 PM
AJ3GS's Avatar
AJ3GS
It has a dual 4ohm voice coil, so I just wired it in parallel to be 8ohm instead. There are videos online doing the same thing.
Old Oct 12, 2023 | 02:18 PM
You mean wired in series. There is a fuse on that sub, unusual.
Old Oct 12, 2023 | 02:21 PM
AJ3GS's Avatar
AJ3GS
Yes, I meant series. I guess the fuse is protection for the sub. It came with some extra ones.
Old Oct 12, 2023 | 02:24 PM
Not a bad idea. Check this out, one of the reviews on Crutchfield they replaced a B&O sub what a pathetic speaker lol.
Old Nov 23, 2023 | 04:47 PM
karm3's Avatar
karm3
6th Gear
Question How did you remove the connector? Seems soldered on mine
Originally Posted by Oceans13
The stock one was metal. Some people took the time to drill it out to make the new sub fit but I found it to be a weste of time. I simply swapped over the rubber ring gasket from the bracket to the underside of the new sub, and just dropped it in. The weight holds it down without an issue. And I had others in the FB group follow my example without issue as well. Up to you.
Also, carefully remove and save the old connector. You can just screw the new sub wires into it.
Old Nov 24, 2023 | 03:21 AM
Oceans13's Avatar
Oceans13
Gently pry / rip it. Or melt the solder with an iron.
Old Nov 25, 2023 | 12:13 AM
karm3's Avatar
karm3
6th Gear
Do you just strip the wire and screw it down to the posts on the new sub? Sorry Im new to speakers and stuff like that, thanks!
Old Nov 25, 2023 | 12:59 AM
AJ3GS's Avatar
AJ3GS
What I did was just cut the wire a little bit before the solder points on the speaker, then used wire strippers to expose the bare wire under the heat-shrink tubing. Since the polk sub has spring connectors, no new soldering was required. Again, I just had to wire two new wires in series to the speaker, then used some wire connectors (specifically two wago connectors) to join the wires to the main wire from the car.
anthne01
Mar 1, 2019 04:21 PM
highvoltag
NX - 1st Gen (2015-2021)
May 30, 2018 12:29 PM
mywong23
Jul 3, 2007 09:18 AM
LexPro
Jul 9, 2003 09:40 AM
spxChrome
31
Apr 15, 2003 08:31 AM
