GS400 Steering Rack Left Bleeder... fix or replace?
Old Sep 16, 2022 | 03:14 PM
sbagdon's Avatar
sbagdon
Default GS400 Steering Rack Left Bleeder... fix or replace?
The steering rack on our GS400 has a bleeder, on the left (driver's) inner tie-rod end... you can see a laminar stream of fluid as you back in to the driveway, and when squeezing the boot, it gushes steering fluid.
Is there a seal in there that's easily replacable (ok, not easily, yet you get the point...!), or are we replacing the entire rack, as it's just easier...?
Thx!
Old Sep 16, 2022 | 05:44 PM
DundukovEM's Avatar
DundukovEM
Based on this diagram, there are no seals on the driver's side. Everything related to the power steering fluid is on the right (passenger side).
There is an OEM Toyota Gasket Kit 04445-30252 which has all the necessary O-rings, seals and gaskets for rack and pinion.
But I am sure that it will be a difficult process with the removal and rebuild of the steering rack.
Get a new steering rack Lexus 44200-30290, ~1k$ and forget about it for another 20 years
Old Sep 17, 2022 | 06:57 AM
sbagdon's Avatar
sbagdon
Sigh, data is good, yet sometimes unpreferable.
Not dropping $1k, can get a rack with 100k inexpensively, online. Will order one, swap, and if it becomes an issue, buy another for 1/10th the price, or go through the discovery exercise of rebulding one of them.
Either way, thanks much for the info...!!! Thx!
Old Sep 19, 2022 | 07:35 AM
dwoods801's Avatar
dwoods801
Have you checked the pressure line and return line for leaks? Plus the pumps are notorious for leaking and then could easily find a way down to the rack. If you haven’t dealt with the power steering pump in the last few years, it’s leaking, get factory rebuilt kit and get it sealed up, and u can get a good look at the Lines while the pump is out. The racks are u usually good unless ran dry and are noisy. Not many have leaks
MikeFig82
Nov 2, 2016 11:48 AM
jim7485
Nov 30, 2015 04:28 PM
ViPeRs103
Oct 28, 2013 03:33 PM
hookem59
May 10, 2009 10:33 PM
Luxor
Maintenance
Jan 21, 2007 10:36 AM
