Transmission issue or normal?
Old Aug 30, 2022 | 08:39 AM
Alan6678's Avatar
Alan6678
Default Transmission issue or normal?
Hello everybody I have a 2003 2GS and always when I do a u-turn on a road the transmission feels like it’s shifting with a drag or feels jerky only while doing u-turns is this normal?
Old Aug 30, 2022 | 08:51 AM
DMPesso's Avatar
DMPesso
Do a drain and fill a few times. Once isn’t nearly enough. Had to do about 4 drain and fills to get the fluid to come out red. It only drains a little over 1 qt each time anyway
Old Aug 30, 2022 | 08:57 AM
Alan6678's Avatar
Alan6678
Yes I’ve done one and drain and fill already perhaps that wasn’t enough to make a difference? The fluid is still nice and red by the way not at all burnt or brown colored.
Old Aug 30, 2022 | 09:25 AM
KyleH's Avatar
KyleH
Not normal. You sure it's transmission and there's not something funky with your rear differential? Doesn't make a ton of sense it only happens on a sharp turn...
Old Aug 30, 2022 | 09:26 AM
Alan6678's Avatar
Alan6678
Im not too sure if it’s the differential I haven’t checked the condition of the fluid yet and don’t know if the previous owner maintained it and yes it only occurs on sharp u turns
Old Aug 30, 2022 | 09:48 AM
DMPesso's Avatar
DMPesso
most definitely not enough. You mean the fluid in the dipstick? That will look clean. It’s when you drain it you will see how dirty it is. You need to drain and fill at least 2 more times, it makes a big difference when it’s done a few times.
Old Sep 2, 2022 | 09:21 AM
Adlib's Avatar
Adlib
Surely any jurking of the rear end when doing a sharp turn has to be diff or suspension, try jacking both rear wheels off the ground and turning one wheel, the oth should freely turn in the opposite direction... Unless you have a diff lock 🤔🤔🤔
Old Sep 2, 2022 | 09:24 AM
Alan6678's Avatar
Alan6678
The jerking usually occurs only in the front end of the vehicle when doing sharp u turns it doesn’t do this all the time but occasionally. But when driving straight the transmission shifts buttery smooth at any acceleration speed.
Old Sep 2, 2022 | 09:37 AM
Adlib's Avatar
Adlib
I would be looking at suspension / tyres, is the tracking OK 🤔
Old Sep 2, 2022 | 09:45 AM
Alan6678's Avatar
Alan6678
Yea I recently got new tires recently they should be fine but maybe I will look at suspension I was thinking motor/tranny mounts possibly
Old Sep 2, 2022 | 09:56 AM
DMPesso's Avatar
DMPesso
Could be the alignment. The 2GS is very sensitive to having a proper alignment. When it’s off the car will drive weird and can definitely make the wheels stutter or jerk
Old Sep 3, 2022 | 10:49 PM
Alan6678's Avatar
Alan6678
Thanks you’ve been a helpful member and appreciate all your feedback 🙏
haitianb0i
Jan 25, 2016 06:04 PM
JT51
Sep 27, 2002 06:02 AM
