Squeaky Steering Wheel
Old Feb 13, 2022 | 08:42 AM
Ajchan's Avatar
Ajchan
Default Squeaky Steering Wheel
I have a 2000 GS400 with about 200k miles. Everything works and the car is quieter and smoother than a new Camry.
My steering wheel recently developed a squeak as it approaches the lock position and is noticeable only when pulling into or out of driveways requiring 90° turns. The steering is fine, and the noise seems to be coming from inside the car. Is there a lube point on the steering column and if so where is it located. Would a shot of white lithium grease solve the problem?
Thanks
Addison
Old Feb 14, 2022 | 04:52 AM
TrueGS300's Avatar
TrueGS300
It's usually where the shaft goes through the rubber seal on the firewall. And yes, usually a shot of lithium grease or even WD40 will quiet it back down. Give it a try.
Old Feb 14, 2022 | 05:15 AM
Ajchan's Avatar
Ajchan
Thanks I get under there today and give it a try. I was concerned Imwoukd have to remove the steering wheel.
RiceBanana
RX - 4th Gen (2016-2022)
Nov 20, 2021 01:56 PM
fabchef
Aug 23, 2021 04:19 PM
Twix
Sep 16, 2010 11:40 PM
