Any Plug And Play Speaker Replacement Options?
Old Feb 8, 2020 | 02:00 PM
chabo3's Avatar
chabo3
Default Any Plug And Play Speaker Replacement Options?
I just got a subwoofer professionally installed and would like to upgrade the speakers myself.
I just wanna pop out the old ones and plug some new ones in. I don't want to build any custom enclosures or install any amps! Do you have any recommendations? Thanks!!
Can I replace the speakers with 4OHMS speakers without changing out any amps? I know you would need an adapter but you can get those on Amazon. I think I'd wanna use these with a "spacer"
https://www.amazon.com/JBL-GTO629-Premium-6-5-Inch-Co-Axial/dp/B00ANIECRQ/ref=zg_bs_10980881_1?_encoding=UTF8&psc=1&refRID=HSCJ0C33FVGHX9PWSH4P https://www.amazon.com/JBL-GTO629-Premium-6-5-Inch-Co-Axial/dp/B00ANIECRQ/ref=zg_bs_10980881_1?_encoding=UTF8&psc=1&refRID=HSCJ0C33FVGHX9PWSH4P
Old Feb 8, 2020 | 04:17 PM
jefthim's Avatar
jefthim
I would recommend the following for adapters...I have used them twice and highly recommend:
http://www.car-speaker-adapters.com/items.php?id=SAK002
Also for front speakers I would recommend these on a budget:. You can spend all kinds of loot on speakers but these are great sounding for the price-point, and yes these like factory are 4ohm speakers. Plug and play.
https://www.crutchfield.com/S-maFGfo...tml?&XVINQ=BIF
Old Feb 9, 2020 | 01:58 AM
rich1068's Avatar
rich1068
2002 UK car with navigation so apologies if there are differences but I found the standard door speakers to be beyond poor. Tried some (really) cheap Pioneers assuming they would be an improvement from factory but they weren't so spent a little more on Alpine S-S40 2 ways. Far better and pop straight in. I disconnected the factory tweeter. https://www.crutchfield.com/p_500SS40/Alpine-S-S40.html
Old Feb 9, 2020 | 11:55 AM
shwalker07's Avatar
shwalker07
Are you currently running the 5.25" door speakers?
You can also look for the 6.5 Mark Levinson speaker boxes found in certain GS models if you do not get the 6.5" template cut-outs. You might get lucky and find a set in a junkyard too:
https://www.ebay.com/itm/MARK-LEVINS...cAAOSwKhhdlWZj
Another option is if you want to modify the factory 5.25" speaker boxes, you can get 6.5" speakers in all 4 boxes if your replacement speakers are not too deep. I did this on mine and just had to relocate the bass tube routing inside the box and make a new hole for it.
Attachment 488381
Attachment 488382
Old Feb 9, 2020 | 03:15 PM
chabo3's Avatar
chabo3
When you disconnected the factory tweeter, did it automatically disable the crossover to the factory tweeter? Or did you have to do something else? Thanks so much!!
I am gonna get 6.5 speakers since people have already made cheap custom enclosures for them and they will work with the factory amp.
Old Feb 13, 2020 | 01:06 AM
rich1068's Avatar
rich1068
Sorry, didn't spot your question.
I didn't do anything other than disconnect the tweeter. I just unplugged it where the connection goes into the top of the enclosure. To be honest I was really surprised how poor the stock sound was. This is my third Lexus of this period and the stock non ML set up has always been fine.
Old Feb 13, 2020 | 09:35 AM
Luxurious's Avatar
Luxurious
Which speakers are those? I am a big fan of that brand and know they awesome quality.
paulfrom94
Jan 15, 2023 11:34 AM
dkotanto
GX - 1st Gen (2003-2009)
25
Apr 29, 2019 07:06 AM
angelrvp
Oct 28, 2015 12:41 AM
SrWilliams
May 19, 2015 08:00 PM
808SC300
Mar 5, 2003 03:23 AM
