Front Suspension Torque Specs Rear Lower Control Arm/Tie Rods ???
Hello all,
Searched everywhere and could not find anything but dead links or no information. Of course you can also get a feel of how tight these bolts should be but I want to to the job right and a functioning tsrm or a front suspension torque diagram would be nice.
I am looking for the front torque specs for the 3 bolts on the rear lower control arm that looks like this:
https://www.rockauto.com/en/moreinfo...426047&jsn=334
Also looking for the the outer tie rod nut (believe it is 45 ft. lbs) and the inner tie rod to rack torque specs.
Thank you all for your help.
The following 2 users liked this post by captainva:
n1ck (03-13-18),
shwalker07 (03-13-18)
Sorry to thread jack, but I have a super noob question.. I've always wondered this but never asked til now. How do I know I am torquing to spec? As an example, lets say I am tightening my lug nuts. I usually just tighten until I can't anymore. I don't necessarily over tighten it and keep trying to force it though. Is this enough or is it still considered to be over tightening?
To tighten to torque specs. You need to have a torque wrench to begin with. You dial in the inch lbs, or ft lbs on your wrench. Then you proceeded to tighten the bolt, or nut until you hear the tool click. You have successfully tightened to the torque spec called out.
https://youtu.be/3v3hLvuO_KU
bryceis250 (07-06-19)
Thanks Muffinizer. Do you have a direct link or a download link for the whole service manual?
LexusK - You should always use a torque wrench with most auto repairs and a standard click type with a bottom dial works good. I keep 3 different ones in different ratings 1/4 (smaller torque specs up to 200in. lbs), 3/8 (for most standard torque specs 20 to 100ft. lbs) and a 1/2 (for high torque specs 20 to 150ft. lbs). Good to also keep them at 0 when storing them as well because over time the torque values will change with wear and tear and should be recalibrated later on.
Like the lug nuts you were talking about some vehicles use as low as 65ft. lbs and some heavy duty trucks I worked on seen up to 165ft.lbs. Most Toyota/Lexus cars use 76-80ft. lbs and some of their truck's/suv's are around 110ft. lbs.
n1ck (03-17-18)
kphu
Suspension and Brakes
07-05-16 12:19 PM
ancdmd
04-11-16 03:25 PM
