Car Stuck In Limp Mode???
Old Apr 29, 2017 | 06:45 PM
SplashBros's Avatar
SplashBros
Default Car Stuck In Limp Mode???
Hoping to get some insight on some car issues. I've done some searching and I'm not quite finding the answers I'm looking for.
Currently my car has the check engine light, VSC light, and VSC OFF light on solid. The car seems to be driving in limp mode.
After running for codes it popped for 11 different codes.
-C0226: Open / Short Hydraulic Brake Booster Solenoid SFR (CURRENT)
-C0236: Open / Short Hydraulic Brake Booster Solenoid SFL
(CURRENT)
-C0246: Open / Short Hydraulic Brake Booster Solenoid SRR
(CURRENT)
-C0256: Open / Short Hydraulic Brake Booster Solenoid SRL
(CURRENT)
-C1251: Pump Motor Is Locked / Open Circuit
(CURRENT)
-C1256: Accumulator Low Pressure Malfunction
(CURRENT)
-C1223: Malfunction In Antilock Brake System Control System
(CURRENT)
-C1201: Engine Control System Malfunction
(CURRENT)
-P0980: Shift Solenoid C Control Circuit High
(HISTORY)
(CURRENT)
(CONFIRMED)
Any advice would be greatly appreciated thank you!
Old May 2, 2017 | 07:24 PM
SplashBros's Avatar
SplashBros
Problem solved 👌🏾
Old May 3, 2017 | 08:47 AM
mistagill's Avatar
mistagill
Originally Posted by SplashBros
Problem solved 👌🏾
What did you end up doing?
Old Sep 27, 2018 | 11:56 PM
ShSh's Avatar
ShSh
Default Codes and remedy
Problem solved 👌🏾
Hi there could you please tell us about the problems you posted and how you solved them?
Old Sep 27, 2018 | 11:59 PM
ShSh's Avatar
ShSh
(CURRENT)
(CURRENT)
(CURRENT)
(CURRENT)
(CURRENT)
(CURRENT)
(CURRENT)
(HISTORY)
(CURRENT)
(CONFIRMED)
How did you fix these error codes? I have them all!!! Thanks.
Old Oct 2, 2018 | 02:44 AM
samsonn25's Avatar
samsonn25
You should be able to clear them with a cheap scanner or TechStream. If it was a electrical glitch it might not come back and car should drive like normal.
If it comes back you have to diagnose further what the codes are telling you.
Old Oct 10, 2018 | 10:58 PM
ShSh's Avatar
ShSh
Thanks for the reply. I actually had an additional P0037 code for the Heated Oxygen sensor heater Control circuit Bank1 Sensor2 (which is the downstream Oxygen sensor for Block 1 pistons 1,2 and 3). I changed the sensor (bought a Denso brand from Auto Zone for $100 or so) and the VSC light and the engine light all went out! I have not gone for another code check but am told this should get my car passed the smog test which is due in a month. I'm sure I will have to fix some stuff in the braking system line but I guess one thing at a time. Thx again.
Old Nov 18, 2018 | 10:48 AM
ShSh's Avatar
ShSh
Car passed the smog check in 15 mins. Cheers.
Socal858
May 31, 2017 10:06 AM
Jack777
Jan 24, 2015 06:47 PM
shrinkwrap
Mar 29, 2014 03:35 AM
Khalendar
Jun 18, 2013 11:19 AM
Hermosa
Dec 8, 2008 04:26 AM
