Blower motor issue
Old Feb 17, 2019 | 07:54 AM
eicca's Avatar
eicca
Power comes from the battery, through the blower fuse, through the blower relay, through the blower resistor module, and then to the blower itself. Test all of those points and determine which of them the power isn't getting past.
Old Jun 17, 2019 | 04:44 PM
Strongman's Avatar
Strongman
Originally Posted by eicca
Try this: Pull the 10A "HEATER" fuse out of the driver's side panel. Then try the blower. If the blower works with the fuse out, I can help you solve that particular pain in the EVER LOVING *** problem that I had to chase down this summer.
If you've had a leak on the passenger side, odds are the problem isn't too complex. But try pulling that fuse just to rule out the worst scenario.
Here's an EWD.
hi i dont know if you still active since this post is like 2 years old but im curious what will be the next step to fix this issue, i removed the heater fuse and my blower motor works, as soon as i reinstall the fuse it stops working again
Old Jun 17, 2019 | 05:06 PM
eicca's Avatar
eicca
See post #72 in this thread for your fix:
https://www.clublexus.com/forums/gs-...ml#post9887037
Old Jun 17, 2019 | 05:31 PM
Strongman's Avatar
Strongman
thank you very much!!!! that fix it.
Old Aug 13, 2019 | 09:39 AM
MrActionGS's Avatar
MrActionGS
Default Lexus gs300 blower motor issues.
I pulled out heater fuse blower works. What else do i have to do??
Old Aug 19, 2019 | 08:05 PM
eicca's Avatar
eicca
Read my post, #18, in this thread.
Old May 9, 2022 | 08:13 PM
Vertigo6's Avatar
Vertigo6
6th Gear
Default Bypassing ECU to get blower motor working.
After a total of at least 14 hours over several days we fixed the problem we had.
All components work except ECU lead to Relay box so we bypassed it.
We didn’t have the heater fuse problem as some have had so we were quite stumped.
Following the lead of people who suggest cutting and grounding the purple wire coming from the ECU wasn’t an option as why cut wires unnecessarily.
​After hours of working on this we have come up with a different solution.
​We opened the relay, cut off and dremeled down the terminal that plugs into the ECU lead in the relay box.
​We soldered a wire to that terminal inside the relay and ran the wire through a drilled hole in the relay cover to a ground under the dash and problem solved.
​No cutting expensive wiring harnesses.
disclaimer: This worked for us, make sure the correct lead is soldered, I am
not responsible if you car blows up 😁
Old Aug 20, 2022 | 11:23 AM
antonioc32's Avatar
antonioc32
1st Gear
can you post pictures of the work have same issue i think
Old Aug 20, 2022 | 01:24 PM
Vertigo6's Avatar
Vertigo6
6th Gear
if this is unclear feel free to email me.
clayton@vertigoperformance.com
Old Apr 18, 2025 | 07:48 PM
Vertigo6's Avatar
Vertigo6
6th Gear
I have just been contacted by somebody about this situation and unfortunately it’s being almost 3 years so I apologize if don’t really recall everything.
On the Aristo the relay is behind the left-hand kick panel.
It was the left tab of the relay we cut off, it was plugged into the purple wire that went to the ECU. We cut the tab off the relay (making sure that there was no way it was going to make contact once plugged back in again) soldered a wire onto it, ran it through a new hole in the relay and then there’s a steel tube up under the dash we drilled a hole in and connected the wire with an eye a self tapping screw.
RollieM
Nov 30, 2024 02:50 PM
SCME87
Nov 17, 2012 09:06 AM
rerose
May 24, 2011 01:21 PM
lexus0239
Sep 23, 2010 02:50 PM
Geoff240ti
Jul 6, 2007 01:55 PM
