Help!!! ABS FUSE REPLACE!!!!
Old Dec 8, 2016 | 10:05 AM
Laza1's Avatar
Laza1
Registered User
Default Help!!! ABS FUSE REPLACE!!!!
Help me!! ABS fuse removed but destroyed!!! Some metal legs can't remove please help!!!
Old Dec 8, 2016 | 11:12 AM
Mr Jokster's Avatar
Mr Jokster
Be creative man, its not the end of the world. I cant really see whats going on there, but needle nose is one way. If they're wedged in there, use an ice pick that is very very sharp or anything of the sort that you can stick in there and pry it out.
Dont for get to disconnect the battery before doing anything.
Old Dec 8, 2016 | 11:14 AM
Mr Jokster's Avatar
Mr Jokster
Worst cast scenario, you can pull the white fuse block (yes the whole thing) out of the black box and I believe you can push it out from behind.
Laza1's Avatar
Laza1
Registered User
I tried but it did not come out
Totally stuck!
Old Dec 8, 2016 | 11:16 AM
Laza1's Avatar
Laza1
Registered User
HOW? I do not want destroy my fuse box! I can't remove fuse box
Old Dec 8, 2016 | 11:17 AM
Mr Jokster's Avatar
Mr Jokster
Now that I think about it, are you sure those are the legs from the fuse and not part of the fuse box itself?
Old Dec 8, 2016 | 11:22 AM
Mr Jokster's Avatar
Mr Jokster
That I'm not sure man. It could be wedged and snapped into the box or it could be screwed to the box. Gotta look around the white part and see if you can see any tabs from the black part holding the white part in place. On my drag car all I had to do was put shims all the way around (between the white and black part) to push out the tabs/indentations from the black part away from the white and it slid right out. But of course all the wires are still attached underneath. No its not an easy thing to do and if you dont believe you're mechanically inclined enough to know what to do next, I wouldnt try it Wires will most likely be needed to be removed from underneath to give you room to work as well as some may fall off on their own. It can be done, but you need to be very conscience of whats going on.
Laza1's Avatar
Laza1
Registered User
Oh my god i don't know! I purchased this fuse:
But i have this with fuse box?
OMG What have i done???????
Old Dec 8, 2016 | 12:38 PM
Mr Jokster's Avatar
Mr Jokster
Well I'm confused, I dont feel like going out and checking my car (I'm under the weather) Some fuses are actually secured to the box, this may be one of them thus the reason you cant put it out.
Maybe someone can chime in on that.
Old Dec 8, 2016 | 02:02 PM
Laza1's Avatar
Laza1
Registered User
Thank you for reply I check my car tomorrow i need a solution :/
Old Dec 9, 2016 | 01:38 AM
Laza1's Avatar
Laza1
Registered User
I just found this!!!!
Old Dec 9, 2016 | 03:11 AM
Laza1's Avatar
Laza1
Registered User
CANT ACCES MY FUSE LINK!! ANYBODY CAN HELP ME??????????
Old Dec 12, 2016 | 04:24 AM
Laza1's Avatar
Laza1
Registered User
Angry
Hello everybody I solved!!! I drilled in the enclosure
Best solution here with pictures!!!!
Old Dec 12, 2016 | 09:57 AM
Mr Jokster's Avatar
Mr Jokster
LoL Did you even attempt to remove the inner block from the black case you drilled in? This is a maintenance item, even if its hard to get to, its not something that would require drilling. Glad you got it out, but that inner block should have snapped right out.
EDIT:
Man, even the video showed how to remove the block haha
Old Dec 12, 2016 | 04:42 PM
Laza1's Avatar
Laza1
Registered User
EDIT:
Man!
If you oit this block without breaking I give you 1 million dollars! 😂👏👏
