Door locks when put into drive.
Old Jan 27, 2016 | 04:46 PM
justim's Avatar
justim
Originally Posted by FrankT
Same cable under $19 on Amazon.
I have tried that one and it's not the same. It works, but locks up frequently. The most visible difference between that model and the one from gearbest is the screws. The Amazon one uses phillips where the gearbest one uses hex.
On the note of techstream, it's fairly cheap. $15 for a 2 day license from Toyota:
https://techinfo.toyota.com/techInfo...tis&_nfpb=true
Old Jan 27, 2016 | 04:53 PM
angus's Avatar
angus
So there you go - a legit way to purchase the real software.
Thanks,
Also can you confirm that gear best cable can program 98-05 cars?
Old Jan 27, 2016 | 10:06 PM
Debonair's Avatar
Debonair
Originally Posted by angus
So are you saying we can't discuss the techstream cable at all or just the software?
Pirated software.
Old Jan 27, 2016 | 10:27 PM
justim's Avatar
justim
I can confirm it works on my 2000 GS300. I changed CBEST settings, ran some of the diagnostic tests and played with the live graphs.
48 hours with techstream is more than enough. After getting all the settings the way I wanted I haven't needed to touch it since.
Old Jan 28, 2016 | 07:13 AM
JJaySilver's Avatar
JJaySilver
Nice. I thought it was a dealer only thing to change c-best setting. I'm going to also buy this thing, it comes with a software CD to have the module on your computer. Do you know if I can program 2 new Lexus OEM master keys? Should be able to right?
Old Jan 28, 2016 | 02:30 PM
justim's Avatar
justim
I have no idea, never tried it but in theory it should. Keep in mind that the CD it comes with is one of those stupid mini CD-R's so a slot loading CD drive wont work. You'll need a regular CD drive to get the drivers onto your computer.
Old Jan 30, 2016 | 07:12 PM
speedkar9's Avatar
speedkar9
I bought a techstream cable from eBay. I was able to pull up the menu for auto-locks on my brother's 2000 GS300, so the option is available.
For some reason though Techstream freezes a lot on his car, but it works fine on every other car I've used it on (ES300, ES330, Sienna, Solara, Rav4).
Here's a demo video I did:
To program new master keys on the GS, you can use techstream, but you can also do it manually, which I did here:
The CD that came with it is a joke. It was corrupted. Technically it is an illegal copy of Techstream.
Old Jan 31, 2016 | 10:29 AM
JJaySilver's Avatar
JJaySilver
That's even better. My car didn't come with a buttoned remote when I bought it. So when I do buy the remote and get it cut I will definitely program it manually. Thanks speedkar9.
Old Mar 1, 2016 | 06:16 PM
lyonkster's Avatar
lyonkster
Is there a way to silence the beep when I use the remote to unlock the doors? All I see are different volume levels, but even the lowest is louder than I'd like. I often leave the house very early in the morning and don't want to annoy the neighbors. Is there an option for a silent remote unlock function?
Old Mar 2, 2016 | 02:11 PM
sakataj's Avatar
sakataj
For some reason though Techstream freezes a lot on his car, but it works fine on every other car I've used it on (ES300, ES330, Sienna, Solara, Rav4)..
MAN you are super Canadian Eh. be careful with talking about pirated software also, its a huge no no on here
Old Mar 2, 2016 | 03:04 PM
ThomasGS4's Avatar
ThomasGS4
You want to make more use of our already notoriously poor door lock actuators?
Old Mar 3, 2016 | 02:37 PM
lyonkster's Avatar
lyonkster
Well after looking some more, I found it. I missed it the first time because this setting is spread over two lines, and "OFF" was in the second line (circled). Interestingly, I wasn't able to change the "84%" value, that might have been a good option too if I could change it to something way lower.
Old Mar 7, 2016 | 06:27 PM
speedkar9's Avatar
speedkar9
Super Canadian? How so?
jlin101
Aug 5, 2016 08:06 AM
Bax
RX - 1st Gen (1999-2003)
Oct 2, 2013 06:35 PM
mno221
Oct 12, 2011 08:29 PM
Mike_TX
Jan 9, 2008 07:42 AM
InTheHole
Dec 12, 2005 10:13 PM
