P0430 code which O2 sensor?
Old May 19, 2015 | 11:09 PM
NoUltimatu's Avatar
NoUltimatu
Default P0430 code which O2 sensor?
I know that 430 is the second (rear) bank. Does one of the 2 fail more often? I did have a bad MAF sensor for about 3 days before I had a chance to fix it.
Old May 20, 2015 | 01:20 PM
Mcon's Avatar
Mcon
If you do not notice much difference in fuel consumption. It is the O2 sensor position 1. Bank 2 Position 1. Is your O2 sensor is up to your cat number 2. Also known as cat piston 4, 5 and 6 which is bad. OEM Part # 89465-30470.
Old May 20, 2015 | 01:57 PM
LadyJay73's Avatar
LadyJay73
I have an '02 GS300 that won't pass inspection because of a P0430 code. Sometimes when I'm driving I hear a gurgling sound coming from the right side. Took it to a mechanic, & he said it was the catalytic converter, & it would cost $2K to fix? Does that sound right?
Old May 20, 2015 | 06:33 PM
NoUltimatu's Avatar
NoUltimatu
Thanks! I appreciate the input.
coug66
Jun 7, 2019 05:02 PM
12340987
Jun 2, 2009 07:26 PM
Gunnut
Jan 27, 2008 10:35 AM
nicos1
Nov 5, 2007 05:47 PM
BklynJay
Performance
Nov 19, 2006 10:39 AM
