Transmission Problem or minor issue?
Old Nov 5, 2014 | 03:07 AM
Lex2sea's Avatar
Lex2sea
Default Transmission Problem or minor issue?
Hey lexus gurus i have a serious question about my 1999 gs300
When i make a right turn instead of kicking into first like a normal car should, it stalls a bit to get into gear almost like it's in neutral but around 1500 rpms it gets into gears, i've taken it to different people and they all gave me different answers one said do a fluid swap another one said it may be an old hose, and the final one said it was a transmission problem that would cost a lot to fix. as a student in college a tranny swap would be a major pitfall in my finances (financial mistake), but if its a smaller issue then that would be great! i know lexus Transmissions are darn near bulletproof and last for god only knows how long!
send help please!!!!!!
Old Nov 5, 2014 | 03:12 AM
Bhubb18's Avatar
Bhubb18
Usual bet would be change the fluid (not flush though).
Old Nov 5, 2014 | 09:19 AM
lexo98's Avatar
lexo98
Not a power flush but if it has been a really long time since the fluid has been changed you will probably need to drain, fill and drive about 3 or 4 times.
Old Nov 6, 2014 | 09:29 AM
DMPesso's Avatar
DMPesso
Yup, only way to fix this is drain and refill your old fluid AT LEAST 4 times in under 50k miles. Its definitely not your tranny, dont worry. Your tranny will probably live longer then you.
Old Nov 6, 2014 | 11:33 PM
Lex2sea's Avatar
Lex2sea
Default Thanks
Thanks y'all for all your help I'll flush the tranny and see how that goes thanks again!!
Old Nov 7, 2014 | 06:37 AM
DMPesso's Avatar
DMPesso
remember flush it at least 3 or 4 times and drive at least 1000-5000 miles between each flush
Old Nov 7, 2014 | 11:46 AM
Doneve79's Avatar
Doneve79
Hey Guys, I have a similar problem w my 2002 GS300. I'm hoping it's not a major thing. Mine does that early in the morning after it sits all night OR parked for a few hours. I'd shift it to Drive & it would not move although I accelerate. Then, all of a sudden it'd shift & drive perfectly normal.
Any suggestions to what can cause that problem?
Old Nov 7, 2014 | 01:31 PM
DMPesso's Avatar
DMPesso
Like I told the other guy, DRAIN and REFILL (NOT flush) your tranny fluid at least 4-5 times with driving 5-10k miles between each drain and fill
Old Nov 7, 2014 | 01:33 PM
DMPesso's Avatar
DMPesso
The problem is always old fluid that has lost it's viscosity. These trannys never go bad unless abused and never had a fluid change. ALWAYS start by changing the fluid as many times as you can to get out as much of that old fluid as possible before you start thinking there is something wrong
sc101
Mar 4, 2013 03:21 PM
Vegas
Feb 7, 2012 02:52 PM
randomwalk
Aug 14, 2011 04:42 PM
mohep
13
Feb 21, 2011 09:58 PM
