OEM LCD touchscreen head unit without Navigation???
Old Oct 10, 2014 | 05:08 PM
Lexobenz's Avatar
Lexobenz
Default OEM LCD touchscreen head unit without Navigation???
What's up, looking for insight, can the oem pre 01 or 01+ touchscreen (navigation) head unit be used for climate control only? ..as in: if I do not have the navigation "brain' or other components.. will it plug & play (less nav of course) for climate control and any other misc. things it does, less the nav?? Thanks in advance.
Old Oct 10, 2014 | 08:53 PM
iToaster's Avatar
iToaster
CL Folding 1,000,000
No, you can't use it without the rest of the system. The navigation screen is just an interface for the computer in the trunk. There is actually no electrical connection between the screen, radio, and climate control modules on the actual head unit, as it is all linked by the computer.
Old Oct 11, 2014 | 05:04 AM
Lexobenz's Avatar
Lexobenz
Thanks a lot IToaster, appreciate it. Would you be able to advise which (I can always look through some of the nav retrofit threads for part #'s) components I'd need, you mentioned the one in the trunk, but I could forgo the actual nav brain, or that IS the nav brain in the trunk...? harnesses?
In short, I like the look of the oem headunit, and would want to put it there for cosmetics, but then I was going to replace the radio portion with a single din flip out (nav/lcd/ec)... BUT not if I have to purchase $1k of oem stuff...that I almost will not use at all.... dilemmas...
Old Oct 11, 2014 | 09:08 AM
angus's Avatar
angus
Sorry, but it won't work without everything.
I am not too sure yet how hard it is to pull the nav harness (or if is part of other harnesses) but I bet you could buy the setup for less than $500.
I know I'll be selling mine soon.
Old Oct 11, 2014 | 12:15 PM
iToaster's Avatar
iToaster
You're better off sticking with the standard climate control. A functional swap requires replacing the complete dashboard and floor wiring harnesses. The unit in the trunk is the navigation computer, which controls all functions of the navigation screen.
Old Oct 11, 2014 | 12:46 PM
angus's Avatar
angus
Are you SURE?
Since those with factory NAV can "downgrade" simply by plugging in a climate control unit - it may stand to reason that if you do not have nag, you can plug in a display and use it as a climate control only...
Not that likely - but plausible...
Old Oct 11, 2014 | 01:01 PM
iToaster's Avatar
iToaster
Originally Posted by angus
Are you SURE?
Without a doubt. I have a navigation head unit for a complete retrofit that I was planning, and the black box for the climate control has no direct connection to the screen. The navigation ECU communicates with it electronically to tell it what to do.
Old Oct 11, 2014 | 02:49 PM
Lexobenz's Avatar
Lexobenz
Not the path of least resistance I was hoping for, but thank you again for sharing your experience, I'm sure it will help others too who come across this thread.
Old Oct 11, 2014 | 02:52 PM
Lexobenz's Avatar
Lexobenz
Thanks too for your input; and if you remember PM me when you're ready to sell, if what you'l be offering will be P-n-p, or 99% pnp. I may very well take take it for a fair deal. Thanks!
PS: Pre or post 01?
Old Oct 12, 2014 | 01:05 AM
DosyBoy's Avatar
DosyBoy
Got my stock Nav and climate control sitting in front of me everything works lights,navi, climate control everything I'm ready to sell right now if that's what u wanted, Came Outta my 400
Old Oct 12, 2014 | 06:21 AM
Lexobenz's Avatar
Lexobenz
DosyBoy, Pm'd ya.
Lin182
Sep 6, 2018 02:14 PM
rpk2012
Feb 23, 2015 03:58 PM
ThumperPup
13
Feb 5, 2013 10:10 AM
natti454
Feb 11, 2009 10:28 AM
much
Jun 8, 2007 09:08 PM
