Speed Sensor
Old Mar 4, 2014 | 08:18 PM
Aristo722's Avatar
Aristo722
After viewing another diagram, I have determined that the speed sensor in the FRONT of the transmission is the VSS. Vehicle Speed Sensor, which controls Speedo and ODO. Now, in our cars, the PCM needs a signal from ABS, VSS and another speed sensor that is located in the rear by the differential, because that is the final drive. The PCM needs two of those signals so it can determine vehicle speed to send to the Speedometer. Now, if your ABS wheel speed sensor is broken, that does not turn off the Speedometer, just throws an ABS,VSC and VSC OFF lights on the dash. Posting this for anyone who may have the same problem, they can view this thread.
Final point. If your Speedo and ODO are not moving, it is the VSS located in the front of the trans. You can try checking the connecting and cleaning it first before replacing, that may fix the problem, if not. Replace it. Hope this helps, Ill get started on thursday and post again with my conclusion.
Old Mar 5, 2014 | 11:01 AM
mrrhr4's Avatar
mrrhr4
Im having a similar problem, Replaced one wheel sensor already (front passenger) i have been hitting the brakes and the car will start to come to a stop, then at the end of at the stop it skips or hick ups causing the car to jolt forward... brakes also make a strange buzzing noise and stiffes.. no abs or ,vsc lights or check engine.. also having hard time going into 1st and 2nd... Transmission revs high in 1st and 2nd and slams into gear occasionally.. any help would be awesome!!!
Old Mar 6, 2014 | 01:31 PM
aliga's Avatar
aliga
Former Sponsor
if you require any of these sensors i have them from good running cars.
Old Mar 8, 2014 | 01:56 AM
Aristo722's Avatar
Aristo722
So, I cant really seem to get to the VSS at all, thought I could just wiggle my hand up there. But it turns out, to access the VSS.... you might just have to drop the transmission. Anyone else know a way to get to the VSS?
Old Mar 8, 2014 | 07:36 PM
Aristo722's Avatar
Aristo722
So anyone may know how to get to the VSS without dropping the transmission or?
Old Mar 10, 2014 | 12:14 AM
Aristo722's Avatar
Aristo722
You part out GS's then right? So maybe you can answer my question. Anyway to get to the Vehicle Speed Sensor without dropping the transmission?
Old Mar 10, 2014 | 10:06 AM
aliga's Avatar
aliga
Former Sponsor
that i am unaware of, sorry. hit up turbo819 on here, he has a few of these transmissions on the ground, and can tell you where they are located.
Old Mar 11, 2014 | 12:04 PM
Aristo722's Avatar
Aristo722
Thank you!
Old Sep 26, 2015 | 09:02 AM
Conmar's Avatar
Conmar
Originally Posted by Aristo722
Thank you!
What ever happened with this? A little old, but maybe someone found a way to access the sensor easier than dropping the trans
zombie
RX - 1st Gen (1999-2003)
18
Dec 4, 2023 07:16 AM
Jesterking
Jan 16, 2019 04:57 PM
Smileme
Nov 21, 2018 07:05 PM
johnnyg66
Apr 7, 2017 08:32 PM
Greg5OH
Aug 19, 2016 04:16 PM
