help me diagnose a prob please
Old Jan 5, 2003 | 08:42 PM
ATLgs4's Avatar
ATLgs4
Default help me diagnose a prob please
i have a gurgling noise coming from the dash area. i can only hear it when accelerating form a dead stop. it sounds like water swooshing around somehwere near the front vents. i started after my 30k service. i plan to take it back to lexus this week but was wondering if anyone has had this problem. im afraid i wont be able to reproduce the problem when i get there, beacuse it seems more evident when the car is cold. its a 2000 gs400. thanks.
Old Jan 5, 2003 | 09:35 PM
MrSypher's Avatar
MrSypher
Damn I don't know bro.... What you should do is, if you dealership is close to your house or work just see if they could have a tech come out and check it while it's cold... There's a good chance that they'd do it... I hope you find out what's causing that swooshing... Goodluck....
Old Jan 5, 2003 | 10:29 PM
Ag02M5's Avatar
Ag02M5
Hmmm....I think I've posted this about 4 times.
It is most likely air in your coolant system.
Take to dealer.
R
Ag02M5's Avatar
Ag02M5
BTW...I have a 2000 GS4 and the dealer made the noise happen after the 30k service.
R
Old Jan 5, 2003 | 11:30 PM
doug_999's Avatar
doug_999
It is air in the coolant system - you are hearing it in the heater core. My 91 Supra used to do this and then shortly after ended up with a no heat situation which turned out to be a bad head gasket. As you don't have a GS300, then you probably just need to get the air out. If you had a GS300 it would point to a possible bad head gasket.
Old Jan 5, 2003 | 11:41 PM
PlayboyzGS's Avatar
PlayboyzGS
I HAVE A 2000 GS400. I HAD THE EXACT SAME ISSUE. THE PROBLEM IS AIR IN YOUR SYSTEM. WHEN THEY PERFORMED THE COOLANT SERVICE AT 30K THEY LET AIR IN THE SYSTEM. JUST ADD SOME COOLANT AND IT WILL GO AWAY. THIS WILL SAVE A TRIP TO THE DEALER AND THEM POSSIBLY TRYING TO BLAME SOMEONE ELSE. GOOD LUCK
Old Jan 5, 2003 | 11:54 PM
BkLexZ's Avatar
BkLexZ
I got a 99 GS300 and I have the exact same problem. I did not take it to the dealer because I dont have a warranty and the dealer wanted $80 just to take a look. So I just tried to ignore it thinking its no big deal but it is the most annoying sound. Definetely will try to add the coolant. If that works for you post it ok.
Old Jan 6, 2003 | 03:57 AM
salimshah's Avatar
salimshah
25 Year Member
Filling the side resrvoir will not help.
Step by step procedure is:
With the radiator COLD remove the radiator cap. Top up if rquired.
With the cap removed, start the engine.
Turn heater to hot with fan at low speed.
Idle, till the temp rises enough to open the thermostat. (radiator cooling fan turns on). Add coolant slowly if required.
Put the radiator cap back on.
Salim
Old Jan 8, 2003 | 02:36 PM
michael7278's Avatar
michael7278
Had a similar problem, after changing my coolant.
The cause is trapped air in the heater core.
I got rid of it by raising the front of the car (parked on a steep hill) , turning on the heat full blast and reving the engine.
The air passed and I just topped off the radiator.
Good luck
M
99 GS300
Dispin
IS - 1st Gen (2001-2005)
Aug 16, 2014 11:44 PM
95SC400
Mar 19, 2013 10:35 AM
legalease
RX - 1st Gen (1999-2003)
Oct 2, 2012 05:01 AM
inkblot
Oct 5, 2005 04:26 PM
BriMcc
Dec 22, 2002 06:46 PM
