Dim DASH at Night
In the day time GS has the britest dash light,
In the night time GS has dim dash light and you can not override this. This set up by Lexus!
And just as it's setup by Lexus they can change it for you if you want... "C-BEST" Settings.......
DISP EX ON SEN
(Display Extinction ON Sensor) NORMAL
The function changes the amount of light the Automatic Light Control Sensor must detect to dim the instrument panel lights, indicator lights and navigation screen lights from the full illumination condition.
DARK2: Lights will dim in darker conditions.
LIGHT2: Lights will dim in lighter conditions.
The tail lights must be ON for this function to operate.
NOTE: GS430/300 functions operate the same as above, except this function has not effect on gauge lights (speedometer, tachometer, etc.)
DARK2/
DARK1/
NORMAL/
LIGHT1/
LIGHT2
________________________________________________
DISP EX OFF SEN
(Display Extinction OFF Sensor) NORMAL
The function changes the amount of light the Automatic Light Control Sensor must detect to brighten the instrument panel lights, indicator lights and navigation screen lights from the dimmed illumination condition.
DARK2: Lights will brighten in darker conditions.
LIGHT2: Lights will brighten in lighter conditions.
DARK2/
DARK1/
NORMAL/
LIGHT1/
LIGHT2
It can be adjusted via C-Best settings under Section 8 (lighting)
DISP EX ON SEN
DARK2/
DARK1/
NORMAL/
LIGHT1/
LIGHT2
DISP EX OFF SEN
DARK2/
DARK1/
NORMAL/
LIGHT1/
LIGHT2
DARK2/
DARK1/
NORMAL/
LIGHT1/
LIGHT2"
What does it do then?? Just the radio and air controls??
DISP EX ON SEN
DARK2/
DARK1/
NORMAL/
LIGHT1/
LIGHT2
DISP EX OFF SEN
DARK2/
DARK1/
NORMAL/
LIGHT1/
LIGHT2
Is think computer the same one they plug in the socket under the left side of the dash, left of the wheel?? I'd really like to try this out. I'm assuming this will work for a '98 GS4, yes??
I already try this customize or C-Best myself( as a Lexus tech), but the light 1 setting only make my Auto Headlight comes on sooner on my GS430. The dash light still the same, but it's brighter under the sunlight. It's dimmer at night. I think Lexus designed it this way so it won't blind your eyes at night and you can see it more clearer in the sunlight.
I used to have a 95 LS and that thing will blind my eyes if I set to Max.
My rep called Lexus and he said that Lexus knows about it and they are working on a solution. He said they would contact me once the TSB is released.
So whoever said, Its not a problem just a little dim is wrong. My **** is WAY dim. The scarey thing is I think it has something to do with the alternator or something cuz If I sit with the car in park or with the brake pressed for a decent amount of time the dash gets bright again. 3 or 4 miles down the road it'll start getting dim again.
I think this may just be a problem mainly with 02/03 GS430 but it could be more wide spread.
I agree. I think it must have something to do with the alternator. I notice mine getting dim when only at certain times but usually when I'm braking. However, my episode with the tinting and the doors being open lead me to believe that something is going on.
Be interested to hear what your rep says.
Thanks
C
