Restoring Steering. Need help!!!
Old Jan 28, 2012 | 08:01 PM
kmy's Avatar
kmy
Default Restoring Steering. Need help!!!
00 Gs400 w/120k miles. All stock besides exhaust system and K&N filter. No fancy suspensions to screw up the steering.
My GS is loosing a few degrees of steering. Noticeable at hwy speed. Especially when the win blows. Car would still go straight but I'm slightly fighting on the steering wheel to keep it straight. Before I bought this GS last summer I test drove two other GS and their steering is responsive like it should.
What needs replacing? PLEASE BE SPECIFIC.
Things I've tried:
-Ball joints seems to be good.- I jack up the car and try to move the front wheels. Ball joints looks solid.
-Ran two different sets of tires. Still the same
-Struts are BRAND NEW
-Tire pressure is always right.
Thanks in advance.
Old Jan 28, 2012 | 08:08 PM
runyun's Avatar
runyun
Caster bushing. Tons of threads about it in the suspension forum.
Symptom: When driving on the highway and you hit a dip, the car wanders left or right?
Steering doesn't feel responsive?
That or steering rack bushings. My bet is still caster
Old Jan 28, 2012 | 08:10 PM
kmy's Avatar
kmy
Thanks, Yes to both. Will check on those parts.
If anybody got anything else please add.
Old Jan 28, 2012 | 08:21 PM
kmy's Avatar
kmy
How much they go for?
Caster Bushings and Rack bushing.
Local auto parts store?
Dealer price?
Can't seem to find in local auto parts store websites.
Old Jan 28, 2012 | 08:24 PM
ThomasGS4's Avatar
ThomasGS4
I have the same issue and I've replaced my rack bushings....didn't do too much.
I'll have to try the caster bushings next.
Old Jan 28, 2012 | 08:50 PM
kmy's Avatar
kmy
Just so I dont get them mix up. Which one is the Caster Bushing?
Old Jan 28, 2012 | 09:14 PM
GS4_Fiend's Avatar
GS4_Fiend
Have you changed ur tie rods? Get an alignment. Also, it's normal to not track straight when there's wind.
Old Jan 28, 2012 | 09:23 PM
runyun's Avatar
runyun
Go look in the SUSPENSION forum. There are tons about caster bushings
Old Jan 28, 2012 | 09:27 PM
kmy's Avatar
kmy
Tie rods are original. Alignment done about 2mos ago but will go in again after I put new tires in next week since I paid for unlimited alignment for 2yrs. Will check Suspension forum.
Thanks guys.
Old Jan 28, 2012 | 09:38 PM
LuxuryGS3's Avatar
LuxuryGS3
Upgrade to TRD Sways and get new caster arm bushings.
Old Jan 28, 2012 | 10:07 PM
kmy's Avatar
kmy
that could be a great idea but you sure it'll be worth it because I'm planning to stay oem struts/springs BUT i do hate the body roll. Like today when I took a butterfly exit at normal speed but with my little 7yr brother and parents in the car, the body rolls like dead struts when I hit little gap/bumps during the turn. Might do a slight spring lowering(less than 1") but not sure yet.
Old Jan 28, 2012 | 10:25 PM
LuxuryGS3's Avatar
LuxuryGS3
I know so. I'm on coilovers and I still have a decent amount of body roll. Only way to really fix that is TRD Sways and prolly a strut bar and under brace. You will NOT regret those mods, that's a definite.
Old Jan 28, 2012 | 10:41 PM
kmy's Avatar
kmy
You're not talking about the under brace i see under my Gs400 are you? You saying I should upgrade that with a stronger one or get one if I dont have one?
Old Jan 29, 2012 | 07:39 PM
justablkv8's Avatar
justablkv8
1. Check out your inner tie rods:
http://www.youtube.com/watch?v=5MkaagWF8ws
(not the exact car in the video, but the same principle).
2. Replace the lower ball joints. This is PREVENTICE maintenance.
3. Get some steering rack bushings; not sure what I can list on here, but there are oem bushings you can buy as well as a few aftermarket poly bushings.
4. Change out your caster arm bushings they connect to the chassis in the front to the steering/suspension parts. Also check all the lower suspension bushings, they make after market products for these parts as well. Also you should check your upper control arms and lastly your bearings.
Old Jan 29, 2012 | 07:57 PM
Arcadian's Avatar
Arcadian
In the past year, I've replaced rack bushings (poly) struts, caster arm/with bushing, LBJ, (all OEM) upper arms (aftermarket OEM style) and my car is better. I've had 3 alignments done during these various repairs. I'd say that the quality of the alignment is critical, and I'l be honest, I don't know what the ideal specs are. I had two of the alignments done at my buddy's Ford dealership and one was perfection, the other was crap (misaligned steering wheel and all). The one done at Lexus was so-so, and I'll live with it until the winter tires come off. The poly rack bushing though are a real good upgrade for those of us who live in pot-hole land (they help you steer around 'em!)
