Weird Start up question?
Old Jan 26, 2012 | 04:30 PM
LudeNsoL's Avatar
LudeNsoL
Default Weird Start up question?
So I have a weird problem when I start up my car the RPMs drop real low for a quick second then come right back up to normal. It almost feels like the car wants to turn off. Any ideas on what can cause this?
Old Jan 26, 2012 | 05:10 PM
GS4_Fiend's Avatar
GS4_Fiend
Does it happen every time? When did this started to happen? What have u done to ur car? More details....
Old Jan 26, 2012 | 05:32 PM
LudeNsoL's Avatar
LudeNsoL
I got the car about two weeks ago and its been doing it since I bought it. It does it every time I start it. Its less noticeable if its real cold out. Car is completely stock.
Old Jan 26, 2012 | 07:14 PM
Redline26's Avatar
Redline26
I would say first check your battery terminals. The connection could be lose, or you might just need a good cleaning. Have you changed your oil recently?
If that's not the case it could be a bunch of other things like spark plugs or starter, since it is pre-owned like mine. I would start with the battery though. Goodluck
Old Jan 26, 2012 | 08:05 PM
LudeNsoL's Avatar
LudeNsoL
battery could affect the rpms?
Old Jan 26, 2012 | 08:17 PM
Redline26's Avatar
Redline26
It might not have a direct affect, but its worth checking
Old Jan 26, 2012 | 08:18 PM
GS4_Fiend's Avatar
GS4_Fiend
battery will affect everything.... get the battery load tested see if results are good. make sure connections are not loose on the battery post. clean the TB and MAF sensor and we can start from there. It's really hard to diagnose online.
Old Mar 5, 2012 | 06:52 PM
LudeNsoL's Avatar
LudeNsoL
Okay bringing this back since I still have this problem and sometimes I have to give it a little gas or else the car will start up and turn right off. I cleaned the MAF and it seemed that it got worse. It seems like the rpms drop lower when I turn it on. I also got a brand new battery. And it still does it.
Old Mar 5, 2012 | 08:12 PM
denut-L's Avatar
denut-L
I would try a tune up, fuel system cleaning. Good luck
Old Mar 5, 2012 | 08:21 PM
Augs300's Avatar
Augs300
How many miles? Maybe its your fuel filter?
Old Mar 5, 2012 | 08:24 PM
GS4_Fiend's Avatar
GS4_Fiend
Did you clean your TB?
Old Mar 6, 2012 | 03:10 AM
LudeNsoL's Avatar
LudeNsoL
130k im going to clean the tb once it stops raining
Old Mar 6, 2012 | 06:02 AM
MrG4Life's Avatar
MrG4Life
CL Folding 100,000
I miss "Oh Werd". Good luck in the diagnosis.
Old Mar 6, 2012 | 08:24 AM
PUREADDICT's Avatar
PUREADDICT
Please report back if this helps! I'm also experiencing this problem. Happened to me randomly after pumping gas.
KassuX97
May 26, 2019 09:25 PM
isthrizzy
May 1, 2013 05:43 PM
oslouie
Aug 11, 2011 06:49 PM
KrazeMatik
Jan 19, 2011 09:53 PM
1genls400
May 17, 2008 05:21 PM
