Help me find my leak?
Old Oct 27, 2011 | 10:31 PM
HangLoose's Avatar
HangLoose
Default Help me find my leak?
So a little background story, i noticed an oil leak. We thought it was the oil pan gasket. We took out the oil pan found that there was no gasket, just silicone. So we put on in and added silicone. And we also noticed another leak. Weren't too sure what the hell it is. So we left it. Fast forward a week later to today, i jacked up the car and took some pics.
I also have another mystery problem where i make a squeaking noise/rattling noise(like putting a stick in a fan) when i accelerate. Anyone know what could cause that?
Anyway, here is the leak, anyone know what it is or where its coming from?
Its found here.
https://i.imgur.com/VCk5b.jpg
Its on that silver part, and the pan/tank there. Anyone can tell me what they are?
https://i.imgur.com/lCTrD.jpg
https://i.imgur.com/4Q2aB.jpg
https://i.imgur.com/u4LZ5.jpg
I wiped the fluid, the color looks like this.
https://i.imgur.com/aXtls.jpg
And heres the car itself.
https://i.imgur.com/TzbLI.jpg
Old Oct 27, 2011 | 11:34 PM
GS4_Fiend's Avatar
GS4_Fiend
My guess would be the rear main seals.
Old Oct 28, 2011 | 08:17 AM
TWong350's Avatar
TWong350
CL Folding 10,000
While under the car, can you see any oil ABOVE the oil pan itself? You could have a leaking valve cover gasket leaking down the making it look like the oil pan.
And FYI, Toyota doesn't use gaskets on their oil pans. You could have made it worse by putting one on. They use FIPG (Form In Place Gasket). I highly recommend the factory Toyota stuff, which is black in color, and also pretty pricey but is really good stuff.
Can you take a sample of your trans fluid to compare to this one? Also a sample of your engine oil too. This could give clues if it's trans or engine fluid/oil.
Old Oct 28, 2011 | 09:42 AM
D-Boi's Avatar
D-Boi
I have the same exact leak and its not from my valve cover. its either rear main seal or oil pan and in your case its not the oil pan.
Old Oct 28, 2011 | 12:02 PM
slickgt1's Avatar
slickgt1
Seems like rear main seal. ***** job, but doable.
Old Oct 28, 2011 | 12:47 PM
HangLoose's Avatar
HangLoose
I would doubt that its trans fluid. The trans fluid is a redish pink color
I didnt know the oil pan had no gasket. Thats interesting. But if the sealant from oem is black, when we removed it, it was white/beige
Old Oct 28, 2011 | 12:55 PM
TWong350's Avatar
TWong350
CL Folding 10,000
Yes, trans fluid is redish pink when it's new and clean. It turns darker if not serviced well.
White/Beige would indicate that someone has removed it and resealed it in the past.
Old Oct 28, 2011 | 08:33 PM
HangLoose's Avatar
HangLoose
I would highly doubt its the trans fluid, i looked at the trans fluid few days ago, looks good still.
Old Oct 28, 2011 | 08:47 PM
TWong350's Avatar
TWong350
CL Folding 10,000
OK... Just a suggestion on other things to consider.
snydertalo
Jan 11, 2015 11:20 PM
jayr0422
Nov 29, 2009 04:43 PM
funyunz
RX - 1st Gen (1999-2003)
14
Nov 8, 2009 05:43 PM
0nePutt
Maintenance
Oct 25, 2009 02:17 AM
HeisLegend
Jun 25, 2009 08:38 PM
