tailight error
Old Aug 11, 2011 | 03:14 PM
99gs713's Avatar
99gs713
Default tailight error
what could be some possible problems for the tail light error light
i think my spolier light is a led one could this throw the code
Old Aug 11, 2011 | 03:38 PM
L3XOTIC's Avatar
L3XOTIC
If its LED lights then itll throw off an error unless you have the load resistors
Old Aug 11, 2011 | 03:51 PM
GS4_Fiend's Avatar
GS4_Fiend
one of your brake light is out.
Old Jan 1, 2012 | 07:51 PM
LexiBlue's Avatar
LexiBlue
brake light out tail light out some led tails will also trip the sensor aswell
Old Feb 9, 2012 | 07:05 PM
kamikaze04's Avatar
kamikaze04
have you figured out the problem?? bc i am currently having the same issue
Old Feb 9, 2012 | 07:45 PM
GS4_Fiend's Avatar
GS4_Fiend
what kind of tail light you got?
Old Feb 9, 2012 | 07:53 PM
DosyBoy's Avatar
DosyBoy
Mine stayed on 24/7 because of my led taillights, I pulled the bulb from behind the dash, took 60 seconds, so much better.....
Old Feb 10, 2012 | 02:01 PM
jriggs's Avatar
jriggs
Questions:
1) Do all your lights light up in the rear?
2) Do you have cheap LED tail lamps without proper resistors built in?
Answers:
1)
replace burnt out bulbs
replace damaged bulb housing and replace bulb
2)
Remove cheap LED tails and install a quality set
Figure out the resistance needed
Remove bulb in cluster and except that you really have a light on
noondogz
Apr 25, 2013 08:51 AM
RTSM
Apr 9, 2012 12:13 PM
yaQuzza
Oct 19, 2011 05:10 PM
JemmyTran
Oct 12, 2008 12:08 PM
BA_GS400
Lighting
May 22, 2005 09:55 PM
