Need Help..
Old Jun 7, 2011 | 09:19 PM
GsLex00's Avatar
GsLex00
Default Need Help..
Driving my GS down the street and all of a sudden the engine starts to cut out...i try giving it more gas and it only seems to exacerbate the problem. Eventually it cuts out, i start it and it'll idle for about a minute or so and if i try to rev it up its really hesitant and just wants to shut off. Now it won't even turn over..any help here??? I think it's a fuel problem of some kind..maybe a fuel filter or pump.
thanks in advance
_Tom
Old Jun 7, 2011 | 09:22 PM
kit cat's Avatar
kit cat
did you check that the MAF sensor is connected?
Old Jun 7, 2011 | 09:28 PM
GsLex00's Avatar
GsLex00
oh yes I tried replacing the MAF and the Throttle Position sensor..no luck
Old Jun 8, 2011 | 08:44 AM
lexybaby77's Avatar
lexybaby77
this happened to my bro a few years back. after days of trying to figure out whats wrong, finally we replaced the fuel pump and it worked till this day.
Old Jun 8, 2011 | 08:47 AM
ThomasGS4's Avatar
ThomasGS4
Wait...did you replace the TPS without adjusting it to OEM specs?
Old Jun 8, 2011 | 03:51 PM
GsLex00's Avatar
GsLex00
doesn't the TPS already come adjusted to OEM specs?
Old Jun 8, 2011 | 04:56 PM
GS4_Fiend's Avatar
GS4_Fiend
In ethics, it could be anything. Asking a vague question like this is not gonna get you no where. I suggest you take it to a mechanic and stop the guessing game. Just saying.
Old Jun 8, 2011 | 05:00 PM
ThomasGS4's Avatar
ThomasGS4
Nope, not at all. There's two screws on the side that you loosen so you can twist the TPS and adjust it. It has to be spot on.
Old Jun 8, 2011 | 06:42 PM
GsLex00's Avatar
GsLex00
damn and thnx GS4fiend I'm sure il make my way to the mechanic but I always try the cheaper solution first
glenwell
Jan 3, 2016 03:37 PM
SCHolmes
May 30, 2014 03:12 PM
CallMeLEX
Dec 10, 2012 08:43 PM
2jz02
Performance
Feb 4, 2010 05:52 AM
mjl_rasta
Performance
Oct 3, 2009 11:36 PM
