Speedometer !!!
Old May 19, 2011 | 08:35 PM
GSRSRT's Avatar
GSRSRT
Default Speedometer !!!
What cases the speedometer to stop showing what speed your going? This happened to me today and idk what it can be i pulled it out and all the plugs seems to be fine. Can it be a fuse !
Old May 20, 2011 | 04:53 AM
starfyrels's Avatar
starfyrels
Account under Legal Action - Banned
fuse, trans speed sensor, yawrate sensor or abs speed sensors. i'm leaning towards abs.
Old May 20, 2011 | 12:13 PM
GSRSRT's Avatar
GSRSRT
smh and I do have my abs lights on! maybe if I clean it. Might start working again !
Old May 20, 2011 | 01:44 PM
starfyrels's Avatar
starfyrels
Do the ohm test. You don't even have to remove the sensor. Search for the threads on how to. Report back if you can't find it.
Old May 20, 2011 | 04:52 PM
LexiBlue's Avatar
LexiBlue
disconect battery for 5 minutes and it should work
Old May 20, 2011 | 06:19 PM
starfyrels's Avatar
starfyrels
^ can you stop posting things you dont know about? Thats misinformation. ABS/vsc lights do not reset themselves by pulling the battery.
Old May 20, 2011 | 08:00 PM
GSRSRT's Avatar
GSRSRT
I'll let you guys know what happens tomorrow !
Old May 20, 2011 | 08:02 PM
GS4_Fiend's Avatar
GS4_Fiend
Are the ABS/VSC lights on?
Old May 20, 2011 | 10:57 PM
GSRSRT's Avatar
GSRSRT
yes they are on! they came on 4 days ago, after I changed a few suspension parts and I took off the caliper and disc ! some guys told me to do a pin reset but idk how to do this.
Old May 20, 2011 | 11:01 PM
DeanGS's Avatar
DeanGS
If there is a faulty ABS sensor (wheel speed sensor) then you can not get rid of the codes by any method other than fixing or replacing the sensor. One you fix/replace the sensor the codes will go away, at least they did on my car....plugged in the new sensor, started the car and there were no codes. I did not "reset" anything or disconnect the battery.
Old May 21, 2011 | 12:01 AM
GS4_Fiend's Avatar
GS4_Fiend
Ok. Obviously, you got a bad speed sensor. You would need to bring it to a mechanic that has a scanner that is able to read ABS. GL
Old May 21, 2011 | 07:19 AM
sakataj's Avatar
sakataj
sounds like you ripped your speed sensor.......repair or replace it
Old May 21, 2011 | 10:46 AM
LexiBlue's Avatar
LexiBlue
no one was not talking about the abs, I was responding to cluster not working.
Last edited by DaveGS4; May 21, 2011 at 01:05 PM. Reason: removed personal commentary
Old May 21, 2011 | 10:55 AM
LexiBlue's Avatar
LexiBlue
also you may want to check your vvti seleniod and the oil screen below the seleniod if its clogged it will through the vsc and abs code. also faulty o2 sensor aswell.
Last edited by DaveGS4; May 21, 2011 at 01:05 PM. Reason: removed rude personal commentary. Check your PM
Old May 21, 2011 | 07:02 PM
GSRSRT's Avatar
GSRSRT
it could be anything tomorrow I will take the disc of and try to clean the sensor if that does not work, off to the mechanic I go. I hope I don't have to buy this sensor and I'm also goin to check the fuse for the speedometer!
