Hey everybody, time to get some new rotors for my Gs and i was thinking some Drilled/slotted rotors. My car is black on back with gold writing. I ran across some gold looking rotors. I was thinking it might look good with the gold writing but i have chrome rims so it might clash. Your options will be appreciated. Also what kind of drilled/slotted rotors do you have. Lastly how long did they last.
The link to the gold rotors http://www.summitracing.com/parts/EBC-GD781/
most brake gurus will tell you Drilled is not really needed no a days because of better pad technology, in addition to potential stress that may crack your rotors, unless your applications are 120mph plus, circuit racing, and such. even then u still have to inspect your rotors after every event.
if you are going for looks which i think your post is leaning towards, id say get any ebay kit, any color or spray it any color, Pink, Green, Yellow, Gold etc and call it a day.
If you are going for performance, your better getting Brembo Blanks, a Good set of Pads, and hard lines. You can also spray both calipers and rotors gold if you wish.
BTW, the gold is not just a pretty color but a Zinc coating that will wear from the rotor bearing surface once you go for your first ride, it will remain on the hat to protect the exposed areas.
I put these on my GS and they look sweet - but they make the most annoying noise when you're slowing down in a quiet street.........sounds like a rat beating a drum.
thanks for all the info. i did not know you can spray the rotor. i knew the calipers but not the rotors.
what kind of rims did u have b/c i have chrome and idk if it will look good w/ gold peeping out. i know it will match my emblems. Did you try different pads to make the noise stop?
just to clarify,you can spray the rotor hats NOT the rotors themselves.....
that would be silly and it would scrape off when you applied the brakes
Yes, what i do is Just spray the whole rotor focusing on the hats, some over spray may land on the pad surface area but will rub off on brake in period. you may want to take a sand paper to the surface to remove some of the spray also. No biggie
i can SERIOUSLY see some NOOB spraying his whole rotor and going, guys i got into a accident my brakes didnt work right.....
O NO!! LMAO. Thats no good news. Think the gold will look good on my GS.
if you can hold off for a minute till i get my new rotoras for the LS model, i will be removing my rotora slotted rotors and Hawk HP pads from these pics and will be selling them. PM me and maybe we can work out a deal on them and motivate me to do this faster
with SS lines. My GS3 has brembo blanks, Hawk pad, SS line and Fresh Dot3 fluid, and stops very nicely.....
thanks. i like my SS lines but im keeping them and will reuse them on the LS calipers.
this brake setup has plenty of bite but now that i have all that dynamat and the heavy stereo setup i want/need just a little more braking power so i went to the LS swap, if its not enough or i want more i will do a BBK
Nice upgrade. Care full when you bleed, i have had nothing but problems after i bled mine, good luck
i took a wire brush and clean the the whole hat area and place some tape around the rotor area before painting, i use duplicolor color caliper paint and now they look really nice ( as always thanks **** on the rotor) but the pad im using sux big time need to get a some better ones" hint sakataj "
