Car Shaking While Reversing
Old Oct 9, 2010 | 09:40 AM
jnguyenlex's Avatar
jnguyenlex
Default Car Shaking While Reversing
So when reversing at a slow speed, the car shakes back and forth a lot. It only happens in a slow reverse, no problem with Drive, or Reversing quickly. Have any of you guys experienced this or know what might cause this to happen?
Old Oct 9, 2010 | 10:54 AM
GS4_Fiend's Avatar
GS4_Fiend
Uneven worned brakes or slighly warped rotors or caliper pins stuck.
I had this same problem myself. After changing rotors and brakes it was gone. I used up the last of the life of my rotors and brakes lol
Old Oct 9, 2010 | 03:58 PM
gs-ireland's Avatar
gs-ireland
I doubt if the brakes would do that, but if it was, the test would be to do some left foot braking when reversing, this will provide feedback to your left foot via the pedal if the brakes were a problem.
I would check your ATF level first.
Old Oct 9, 2010 | 08:58 PM
gsjason300's Avatar
gsjason300
possibly motor mount???? hahaa im prolly wrong.
Old Oct 10, 2010 | 12:10 AM
swat1727's Avatar
swat1727
it happened to me. i flushed my tanny fluid. it went away.
Old Oct 10, 2010 | 07:15 AM
Frankdorn's Avatar
Frankdorn
Like engine shake, whole car shake, wheel shake?
Old Oct 10, 2010 | 10:10 AM
dealer374's Avatar
dealer374
Used to happen to me but my rear pinion seal is leaking, I Topped off the diff fluid and it went away
Old Oct 10, 2010 | 12:34 PM
jnguyenlex's Avatar
jnguyenlex
Car shaking forward and backward.
Old Oct 10, 2010 | 03:19 PM
gsjason300's Avatar
gsjason300
it possibly is the motor mounts.???
Old Oct 10, 2010 | 10:40 PM
jnguyenlex's Avatar
jnguyenlex
I'll check these reasons once I get some time too. Been busy lately and just wanted some insight on what to check.
Old Oct 11, 2010 | 02:52 AM
Sixdown's Avatar
Sixdown
sounds more like the transmission is jerking the car since he said forwards and backwards.
Old Oct 13, 2010 | 03:27 AM
jjawaya's Avatar
jjawaya
i have this same problem. i have an 05 gs300. took it to my local dealership, flushed the trans and no fix. eventually got them to replace my trans(no cost) and still no fix. long story short, i still have the problem and lexus said that they dont know whats wrong and are not willing to do anything else. i just have to live with it(the same thing as telling me tough s#!t.) i've given up, as no one has been able to give me an answer. if you find a fix, let me know.
Old Oct 13, 2010 | 07:01 AM
Debonair's Avatar
Debonair
I also had this issue. Warped rotors was the cause.
Old Oct 16, 2010 | 06:17 AM
jjawaya's Avatar
jjawaya
im no expert, but wouldn't warped rotors make the car shudder in forward and reverse? i also had all four brakes done after i noticed the problem, so i'm ruling out that possibility. any experts on oahu willing to try and figure out whats going on?
Old Mar 24, 2011 | 01:55 AM
chicov8's Avatar
chicov8
i do have same thing on 2000 Ls400
its shakes/jerking only in revers at low speed
i thought it was transmission so i changed filter and fluid and it didnt fix that problem
right now i thinking it maybe a breaks but i tried it driving forward with my feet an breake and there was shaking
