Car Shaking While Reversing
Old Mar 24, 2011 | 03:57 PM
chicov8's Avatar
chicov8
was anybody able to fix this problem? or you just have to live with it
Old Mar 25, 2011 | 09:36 AM
Blanco's Avatar
Blanco
Have your rear brakes checked.
Old Mar 25, 2011 | 10:10 AM
Debonair's Avatar
Debonair
The problem for me was being caused by rear warped rotors. Machining fixed most of the issue. There was also warping on the inside drum of the rotor, where the emergency brake shoes make contact. Once I had the inner drum machined the issue was gone.
Old Mar 25, 2011 | 01:38 PM
Boostless's Avatar
Boostless
I have the same issue. I've done pads and rotors all around, motor and trans mount too, didnt fix it. My next thing to check is the driveshaft. I know theres the two bubber insulators and the carrier bearing, if these have play it might cause driveshaft slop. Anyone else ever look into this?
Old Mar 25, 2011 | 01:40 PM
Blanco's Avatar
Blanco
I agree with Debonair. Have you checked your parking brake at the rear rotors?
"There was also warping on the inside drum of the rotor, where the emergency brake shoes make contact."
Old Mar 25, 2011 | 02:19 PM
chicov8's Avatar
chicov8
thank you guys
im gona do brakes next (i know i need to do my front breaks) and post results
Old May 14, 2011 | 03:53 PM
chicov8's Avatar
chicov8
i just did my breakes
all pads and rotors and it didnt help
Old May 14, 2011 | 04:28 PM
KingNasGS4's Avatar
KingNasGS4
my car also does this. I changed the motor mounts already and tranny mounts so its not that. The rotors are good.
Idk what it is
Old Oct 8, 2011 | 06:57 PM
Busha's Avatar
Busha
does no one have a answer ????????
Old Oct 8, 2011 | 09:11 PM
clos430's Avatar
clos430
Originally Posted by jnguyenlex
So when reversing at a slow speed, the car shakes back and forth a lot. It only happens in a slow reverse, no problem with Drive, or Reversing quickly. Have any of you guys experienced this or know what might cause this to happen?
Not sure if it's the same problem as this guys, but i have a 05 GS 430 and when i first start the car and put it in reverse it kinda hesitates as soon as i release the brake pedal. So i cleaned out the throttle body and it improve somewhat so i just ended up replacing the throttle body assembly ( ext. warranty ) and it fixed the problem
Old Oct 8, 2011 | 09:53 PM
Blanco's Avatar
Blanco
check your e brake pads in the rear.
Old Jul 29, 2024 | 06:29 PM
TheeGsGuy's Avatar
TheeGsGuy
7th Gear
Default 2004 GS300 rear end shakes entire car up and down while reversing
Hey guys I have the same issues as everyone in this thread are having in my car I have 2 things wrong with it the transmission slips under hard acceleration (When cold only happened twice so not entirely sure) and breaks are squeaky when cold I need help trying to narrow down the issue as when the firestone shop looked at it they could not find anything wrong and then so we took it to the Lexus dealer even they could not figure out what was wrong with the car so they basically told us that they could replace the entire rear subframe and all the drivetrain parts and bushing for a ridiculous amount of money and still said they were not sure if that would even fix it. I need some help trying to diagnose this issue.
hopzhopz
RX - 3rd Gen (2010-2015)
Apr 5, 2016 05:44 AM
Bokenrosie
Jan 10, 2011 06:34 AM
JC07ES350
12
May 7, 2010 07:01 PM
vuman1
Oct 15, 2009 06:19 PM
Rx900
GX - 1st Gen (2003-2009)
20
Jul 7, 2006 12:56 PM
