Rear toe adjustment is seized, advice?
Old Mar 29, 2010 | 10:03 AM
JiBBeL's Avatar
JiBBeL
Default Rear toe adjustment is seized, advice?
Got an alignment over the weekend and dude said he couldn't adjust the toe in the rear on one side because it was seized up. He didn't have a part available to replace, but said the labor would be like $50.
Anybody know what the part name or part number I'd need to replace is? I thought it was called like an eccentric bolt or something. How bout some DIY instructions to save me the $50 labor? A picture of said bolt would be immensely helpful.
Thanx
Old Mar 30, 2010 | 05:41 AM
JiBBeL's Avatar
JiBBeL
bump anyone?
Old Mar 30, 2010 | 07:55 AM
Infamous 1's Avatar
Infamous 1
Get the Megan IS300 rear adjustable toe arms. Its not hard at all to do. Search, there are a few write up about these.
Old Mar 30, 2010 | 10:40 AM
JiBBeL's Avatar
JiBBeL
I don't want aftermarket control arms... I just want to replace the seized bolt, lol.
Old Mar 30, 2010 | 11:09 AM
vwynn's Avatar
vwynn
which bolt or nut is seized?? the one that locks up the adjustment or the adjustment one??
Old Mar 30, 2010 | 11:17 AM
JiBBeL's Avatar
JiBBeL
Guy at Firestone said the adjustment couldn't be made as the bolt was seized, so I assume the latter.
Old Mar 30, 2010 | 01:15 PM
AsGs300's Avatar
AsGs300
same here with the right rear, also my freinds GS , so getting the IS300 rear control arm will fix this?
Old Mar 30, 2010 | 01:45 PM
JiBBeL's Avatar
JiBBeL
Here's what I've gathered so far from talking to Lexus dealer and Firestone:
Lexus: There's two bolts, one toward the center diff, and one toward the wheel, which one do you want, sir?
Firestone: Not sure which one it was last weekend, but our notes say "toe eccentric bolt seized" lol.
I might jack the car up this afternoon and put a wrench on both to see which one it is.
If it's the adjustment one, do you know whether its toward the center of the car or the outside by chance?
I think replacing the entire control arm is overkill. The seized bolt just needs to be cut out and replaced.
Old Mar 30, 2010 | 02:10 PM
vwynn's Avatar
vwynn
Getting the IS300 Rear toe arm will not fix anything if you cant remove the bolt that holds the OEM arm in.
I think the locking nut might be seized.. Try taking a breaker bar to it and see if it frees it up. If you can add a long **** poll to give you more leverage and torque.
Old Mar 30, 2010 | 02:19 PM
JiBBeL's Avatar
JiBBeL
Word, I got the car jacked up and the breaker bar + hammer out now. Cold yueng-ling in hand. I'll report back shortly
Old Mar 30, 2010 | 02:24 PM
FrankT's Avatar
FrankT
Adjust Cam Bolt
part number 48190-30060
$10.00
Adjust Cam Nut
part number 48198-30080
$10.00
KayGeeCee
Sep 14, 2017 12:47 PM
gookies
RX - 1st Gen (1999-2003)
13
May 21, 2017 07:48 PM
ChiChiMan
Sep 17, 2011 06:37 PM
sivikvtec
Suspension and Brakes
Feb 28, 2010 12:54 PM
fireballs gs400
Maintenance
Aug 14, 2006 01:18 PM
