Adjust toe on rear
Old Sep 14, 2011 | 11:54 AM
ChiChiMan's Avatar
ChiChiMan
Default Adjust toe on rear
Hi everyone,
I am hoping someone can help me adjust the toe on my rear left wheel.
I hit a curb and the current reading is +2.3. Needs to be between 0.1 and 0.3
Could someone post a step by step guide on how to fadjust he toe? Also, what tools will I need to do it?
Any help will be greatly appreciated.
Thanks!
Old Sep 14, 2011 | 07:18 PM
ArodDaLob's Avatar
ArodDaLob
a 19mm. If you take off your rear wheel, you'll see a rod that comes out from the front of the hub tot he subframe. That bolt that holds the arm onto the subframe is eccentric. Mark it first (just for reference) then loosen the nut and turn the bolt to either push the front of the hub out or pull the hub in to toe it out or in.
Old Sep 14, 2011 | 07:52 PM
philvia's Avatar
philvia
The toe link is probably bent with that much toe in, might have to get a new one
Old Sep 14, 2011 | 11:38 PM
topdog849's Avatar
topdog849
yeah if you have that much toe the stock alignment adjustments wont be able to compensate. time for battle version traction rods and toe links. i got mine on driftspeed
Old Sep 15, 2011 | 10:46 AM
ChiChiMan's Avatar
ChiChiMan
Thanks a lot for the replies. How hard is it to install a new toe link? Thanks.
Old Sep 15, 2011 | 11:08 AM
topdog849's Avatar
topdog849
not too hard but you will need an alignment right afterwards. how does ur camber look
Old Sep 15, 2011 | 12:03 PM
ArodDaLob's Avatar
ArodDaLob
installing new toe links isn't really hard at all. you just need a 19mm socket/wrench, and something to pull the ball joint out, i recommend something like a pitman puller. Bver sells a pair for 195$, i'm not sure about shipping though.
Old Sep 15, 2011 | 12:09 PM
topdog849's Avatar
topdog849
if no pitpan puller a big fckn hammer will work
Old Sep 15, 2011 | 12:54 PM
ChiChiMan's Avatar
ChiChiMan
Hi topdog,
Left Camber 0.1
Right Camber -1.7
Recommended specs are between -1.6 and -0.1
Left Toe 2.3
Right Toe -0.1
What do you think? Will replacing the toe links be enough?
ArodDaLob: I guess I have to replace on both sides?
Once again, thanks for all the help.
Old Sep 15, 2011 | 01:00 PM
topdog849's Avatar
topdog849
are you lowered? if not you may be able to get away with stock camber adjustments. all of my alignment readings are everywhere so I'm in the process of new bv traction rods, toe links, rear and front lower control arms. then my steering wheel should finally be straight
Old Sep 15, 2011 | 01:28 PM
ChiChiMan's Avatar
ChiChiMan
No, not lowered. Do you plan to do all that work yourself? So you think stock camber adjustment and toe link replacement should fix this? Thanks
Old Sep 15, 2011 | 01:48 PM
topdog849's Avatar
topdog849
I'm a couple certification away from being a master automotive technician so yeah I do everything myself. use a straight edge to see if you toe link is bent.
Old Sep 15, 2011 | 04:53 PM
Nova's Avatar
Nova
chichiman are you using an alignment machine to get your specs or are you having someone check the spec for u after you adjust??? most alignment machines should come with a guide and i know for certain that a Hunter Alignment machine will give you step by step instructions, a list of tools needed as well as a plethora of other features
Old Sep 17, 2011 | 01:42 PM
ChiChiMan's Avatar
ChiChiMan
Hi, here's a pic of the parts behind the wheel. The two parts seem very slightly bent. Could that be causing the 2.3 positive toe?
Thanks
Attached Thumbnails Adjust toe on rear-car-pic-september-seventeen-two-thousand-and-eleven-006.jpg
Old Sep 17, 2011 | 06:37 PM
topdog849's Avatar
topdog849
yeah it's bent. if you don't want to shell out 500+$ for aftermarket links and rods I can grab you just the side you need from my local junkyard for a fraction of the price. pm me if interested.
gookies
RX - 1st Gen (1999-2003)
13
May 21, 2017 07:48 PM
lextout
Suspension and Brakes
Mar 13, 2015 09:48 PM
DannySz
12
Feb 24, 2013 11:50 AM
sputniknyc
Jul 31, 2012 08:46 PM
tiger4life
Dec 21, 2010 11:49 AM
