Spring Problems Need Help!
Old Mar 18, 2010 | 04:59 PM
NewNorth's Avatar
NewNorth
Default Spring Problems Need Help!
So my GS300's been sitting in the garage all winter due to the great Minnesota weather. It finally started warming up the last couple days so yesterday I tried to start it up and it was dead from sitting all winter. Well the battery wouldn't take a charge so I ended up getting a new battery swapped out today.
When hooking up with new battery I noticed something I have never witnessed before. After putting on the positive, I connect the negative and the horn comes on full blast and the headlights come on. Its not like the typical security beep that you turn off with your key and everythings cool. The horn goes off in 1 full constant sound like if you were laying on it and when trying to turn it off with the key fob or unlock/locking the door manually it wont turn off.
Before I shut it down for the winter everything was perfect with it so I can't figure out whats going on...any ideas???
Old Mar 19, 2010 | 07:08 AM
Infamous 1's Avatar
Infamous 1
Check to see if there is an aftermarket alarm installed. Look under the steering column for a black box that doesn't belong.
Old Mar 19, 2010 | 09:47 PM
NewNorth's Avatar
NewNorth
No Aftermarket Alarm, any other ideas?
Old Mar 19, 2010 | 09:57 PM
Spyder78's Avatar
Spyder78
CL Folding 25,000
check to see if there is a short somewhere. Check to make sure no mice or other critters havent chewed up your wiring. Check the fuses.
athomemom
Apr 26, 2019 07:39 AM
BossGS4
Aug 10, 2017 01:59 PM
BoyOhBoy
Jul 18, 2014 12:54 PM
glex4
Apr 22, 2014 08:37 PM
jmezo
Jan 26, 2014 08:17 PM
