just wondering about this
Subscribe
Sep 11, 2009 | 12:26 PM
this ? is really for people with a OEM nav system who have installed aftermarket audio components.
before i install my diamond D6 component sets,tweeters,etc when you install these does the nav STILL cut over the aftermarket speakers like it did when you have a oem setup. seems silly but i was thinking bout this driving home yesterday and i like it so i dont wish to lose it.
Reply 0
Sep 11, 2009 | 12:31 PM
My new 430 has nav/mark levingson and xm sat. I just got the car 4 days ago so I havn't messed with the xm too much yet, but I can tell you that the nav still talks over cd's. I'll try xm when I get home today and let you know.
Reply 0
Sep 11, 2009 | 01:07 PM
Quote: My new 430 has nav/mark levingson and xm sat. I just got the car 4 days ago so I havn't messed with the xm too much yet, but I can tell you that the nav still talks over cd's. I'll try xm when I get home today and let you know.
over cd's and xm, yes i know it will specially since im assuming your still using your OEM ML speakers. i mean when i pull my OEM ML speakers out and replace them will it cut over the NEW speakers?
Reply 0
Sep 14, 2009 | 10:44 AM
anyone know about this?
Reply 0
Sep 14, 2009 | 12:33 PM
I have stock nav with dynaudio speakers ppi amps. Also I wired up my whole system. It is up to you if you want the nav to cut over the new speakers. or you can do what i did and just rewire it to the center speaker since you wont really need it when you add new door speakers. If i remember right, basically you can tap into the audio lines coming right out of the levinson amp in the trunk to run to your line converter and then to your amps. (i use a rf 360.2)
and the front left speaker(driver door) actually goes from the levinson amp to the nav unit in the trunk and then goes to the front door. ( this is where it taps into the line) So it is your choice where you want to tap in to the line, before or after the front left speaker line goes to the nav system. Or you can do what i did and tap into it before it goes to the nav system this way the speakers nav never cuts into the door speakers. and then rewire the center speaker to the nav so that the center speaker is only used for the nav. All of this can be done from the trunk.
Hope i explained it good enough.
Oh yeah I also ran new wires from the amps in the trunk to all doors. I strongly recommend you do also.
Reply 0
Sep 14, 2009 | 01:46 PM
im running 2 10s jl w6 and a diamond audio amp.... with my stock navi, slaps pretty hard but would be better with a double din deck tho =]
Reply 0
Sep 15, 2009 | 10:03 AM
Quote: I have stock nav with dynaudio speakers ppi amps. Also I wired up my whole system. It is up to you if you want the nav to cut over the new speakers. or you can do what i did and just rewire it to the center speaker since you wont really need it when you add new door speakers. If i remember right, basically you can tap into the audio lines coming right out of the levinson amp in the trunk to run to your line converter and then to your amps. (i use a rf 360.2)
thanks for the info....yeah it comes and handy. i'll look at it when i start installing the weekend. lol of course i will run new wires....
Quote: im running 2 10s jl w6 and a diamond audio amp.... with my stock navi, slaps pretty hard but would be better with a double din deck tho =]
um thats awesome and all but WTF does that have to do with what im asking?
Reply 0
Oct 2, 2009 | 10:59 AM
so....again.....
Reply 0
Oct 2, 2009 | 12:43 PM
If you're only swapping speakers then it should still interupt.
Reply 0
Oct 5, 2009 | 08:01 AM
Quote: If you're only swapping speakers then it should still interupt.
right now, im swapping speakers AND removing OEM ML amp to install other amp and speakers but ATT im essentially just swapping speakers
thanks
Reply 0
Oct 5, 2009 | 09:32 AM
Yes it will still interrupt as the input is still the same.
Reply 0
Oct 5, 2009 | 10:03 AM
Quote: Yes it will still interrupt as the input is still the same.
cool, ty guys
Reply 0
Subscribe
