Drivers Window Problem - Need Help
Old Sep 1, 2009 | 08:50 PM
Lexizm's Avatar
Lexizm
Default Drivers Window Problem - Need Help
I just started having this problem about a week ago. I had the drivers side window down and went to use the auto-up feature and the window started to go auto-down. This has happened a few times now. I'm thinking I need a new switch but I did some research and found some were having problems with the window regulator. How can I tell if the problem is with the switch or the regulator??
I plan on fixing the problem at the same time I do the door actuator since the panel will be off. Any help would be appreciated.
lexusondubs
Jun 7, 2011 09:16 AM
bcorreia
Jun 23, 2010 09:34 PM
tuninghaus
Jun 25, 2007 01:46 AM
97-SC300
Jun 30, 2006 01:47 PM
