Gs problems
Old Aug 6, 2009 | 07:10 PM
dbk_yu's Avatar
dbk_yu
Default Gs problems
There is a slight bubbling sound on the passenger side, and brakes squeal but mechanic says the pads are pretty much brand new. How to fix?
Old Aug 6, 2009 | 07:26 PM
5t341th's Avatar
5t341th
for the squealing, you could try using brake lube/grease on the back of the pads and it might fix it
Old Aug 6, 2009 | 07:57 PM
dbk_yu's Avatar
dbk_yu
how to apply? just lube up? or take pad out and lube?
Old Aug 7, 2009 | 12:53 AM
GS4_Fiend's Avatar
GS4_Fiend
The splash guard for the rotors might be touching.
Old Aug 7, 2009 | 04:53 AM
Mike813's Avatar
Mike813
if you add the brake quiet stuff try to get the back of the pad where the caliper cylinders touches the pad also try not to get it on the rotors... add some onto where the 2 sits on the top & bottom fittings of the pads.
you do not need to remove the pad itself to get to it, just hang the caliper down and apply but turn the wheel a little to get to the inner pad.
pman6
Mar 2, 2017 04:34 AM
lexrally
RX - 1st Gen (1999-2003)
13
Jul 15, 2015 01:18 PM
sf3r8z
Apr 9, 2014 02:39 PM
lexus-is2
Suspension and Brakes
Oct 19, 2012 05:43 PM
nysupraman
Wheels, Tires & Brakes Forum
Apr 29, 2004 01:15 AM
