Guys with HID .... HELP!
I got a OEM HID headlight and I want to put it in the ride....BUT there are two plugs.....I beilve my non HID GS only has the 9006 connector right? What goes where and am I missing a plug?
No sweat! The small white connector is your power and ground for the low beams. The large black connector is for the leveling motor. Just cover that one. Remove the pins from the low beam connector attached to your wire loom. Them attach them to the two pins in the small white connector(red wire is power). Then the hids will work. PM me with your day phone number is you need more help.
DD
DD
dude..
why dont you get one of those .. HID kits.. they'll give out better output then oem hid's and plus you wont have this headache.. this whole upgrade going take 2 minutes of your time
in this pic it looks like a wire splitter harness which only has a red/black connector at the top and attaches to the leveler too.....would the leveler just use an internal leveling device inside the headlight? Would this work?
