im extremly upset
Old May 26, 2009 | 09:06 PM
718LS430's Avatar
718LS430
Default im extremly upset
i woke up yesterday to find out that i had a flat . tonight i try to change it and BANg my freaking lug that uses the special key broke with the lug stuck in it and the rest still on the bolt .. is this a thing that happens often . i guess its cause lexus used a cheap lug that it can snap that easily .. any advise maybe to an after market one that i can get which is a better quality
Old May 27, 2009 | 07:07 AM
Debonair's Avatar
Debonair
That sucks, sorry to hear. Must have been over torqued or cross threaded at some point in its life.
Old May 27, 2009 | 09:09 AM
Infamous 1's Avatar
Infamous 1
They make a lug out kit. It's an impact socket that has a reverse thread on the inside. This is generally used for people who loose their keys or people like yourself that break it. If you can't do it yourself, then take it to your local mechanic. Good luck!
Old May 27, 2009 | 09:14 AM
IXI187IXI's Avatar
IXI187IXI
either that or if you have any 12 point sockets, you can get one slightly smaller than the lug and hammer it on. ive removed a few lugs that way.
Old May 27, 2009 | 11:23 AM
Alexus_300's Avatar
Alexus_300
either use a 20mm 12pt socket or use a bolt out socket.
Old May 27, 2009 | 11:51 AM
oohpapi44's Avatar
oohpapi44
CL Folding 100,000
Has anyone tried this from the televions ads?
http://www.asseenontv.com/prod-pages...OL_OUTDOOR_PET
Old May 27, 2009 | 01:31 PM
sakataj's Avatar
sakataj
not tried that one specifically but we sell a similar tool at work and i have used that although im interested in this one as it is less complex
Old May 27, 2009 | 02:16 PM
raytseng's Avatar
raytseng
Was featured on an episode of PitchMen.
It looks like it works really well, but is meant for on screws/bolts.
I don't think it'll work for the amount of impact torque needed to free a tire lug nut.
Even when you have full contact on the lug it takes quite a bit of impact. With standard trunk emergency tools, where you have complete contact on the lug, typically you can't remove a lug nut by handyou got to step on the handle with all your weight to free it (unless you have a breaker bar).
rnourse
Mar 20, 2012 09:52 AM
daryll40
Oct 24, 2011 01:57 PM
IXI187IXI
NELOC
14
Sep 9, 2010 03:50 AM
dung0981
CL of Southern California
Apr 14, 2009 04:43 PM
costanza
Feb 18, 2009 08:46 AM
