P1349 OBD code
Old Feb 24, 2009 | 04:30 PM
subzero32's Avatar
subzero32
Default P1349 OBD code
My car threw this code, I'm thinking that the timing belt needs to be replaced, any thoughts?
Old Feb 24, 2009 | 05:54 PM
Euro09's Avatar
Euro09
P1349: "VVT System Malfunction (Bank 1)"
Are u sure is bank1 or bank 1b ? if its a bank1b then read the threat below,
https://www.clublexus.com/forums/gs-...ve-filter.html
Old Feb 25, 2009 | 09:27 PM
mayad79's Avatar
mayad79
Default Similar problem
I had a similar problem with the same code plus misfire codes for all 8 cylinders. The accelerator position sensor and the TB were replaced. The sensor by itself did not solve the problem. The final piece was the tb replacement.
Also could be the selenoid for the vvti there are two.
I inspected the old tb and it was gunked up, but a cleaning made little improvement.
hope it helps, I am not an expert....
Old Feb 25, 2009 | 09:58 PM
GS4_Fiend's Avatar
GS4_Fiend
search button
Old Feb 26, 2009 | 10:42 AM
sakataj's Avatar
sakataj
Originally Posted by GS4_Fiend
search button
whats that? just teasing
Old Mar 1, 2009 | 02:20 PM
subzero32's Avatar
subzero32
So I pulled out the oil filter that goes to the VVT and cleaned it with brake cleaner and it didn't do anything to fix the problem. The check engine light is still on , blinking now, The VSC and VSC off lights are on also with a rough idle. I had the dealership check the code and they said it was the oil filter to the VVT, Any more ideas?
Old Mar 1, 2009 | 02:28 PM
BCP43002's Avatar
BCP43002
For a code of P1349 = VVT System Malfunction (Bank
1) possible causes are the following:
1.Valve timing
2.OCV
3. VVT controller assembly
4.ECM
Old Mar 1, 2009 | 03:08 PM
subzero32's Avatar
subzero32
1.Valve timing
2.OCV
4.ECM
I have that exact list in my hand from Autozone OBDII readout, I'm just wondering what the best choice is considering what I have done and my symptoms.
Old Mar 1, 2009 | 03:48 PM
GS4_Fiend's Avatar
GS4_Fiend
search button. there is a diy on this.
Old Mar 2, 2009 | 10:35 AM
sakataj's Avatar
sakataj
maybe u could help our new friend and post him a link this one time?
Old Mar 2, 2009 | 03:20 PM
Jason T's Avatar
Jason T
You may need to remove the OCV and clean the piston this must move freely follow the link bellow it will show you how to test the oil control valve
Check your codes after removing neg batter terminal via DIAGNOSTIC block in engine bay terminal TC & E1 with a paper clip
Dash lights will all flash count the orange engine light only
http://bahamutcars.free.fr/workshop/...nts/index.html
Repair Manual / DIAGNOSTICS / ENGINE this will take you to engine fault code list
Code via OBD2 Scanner is P1349 via engine check light is 59
Follow the flow charts to fix
Old Mar 2, 2009 | 07:51 PM
GS4_Fiend's Avatar
GS4_Fiend
Nicely said...
Old Mar 5, 2009 | 07:57 PM
subzero32's Avatar
subzero32
So it seems it is the VVTi solonoid that needs to be replaced, i'm still waiting for it to come in at the dealer. I'll keep you guys posted on it.
Old Mar 16, 2009 | 02:04 PM
subzero32's Avatar
subzero32
So I installed the VVTi solonoid today and the check engine light is still on! Also the VSC and VSC off lights are on, any ideas?
Old Mar 16, 2009 | 05:51 PM
BCP43002's Avatar
BCP43002
Reset the light by removing the neg cable from your battery for a few minutes. Then reconnect and take for a test drive to see if it reapears.
