rubbing noise
Old Oct 7, 2008 | 01:59 PM
ppgs400's Avatar
ppgs400
Default rubbing noise
Hello, I have an 03 GS430 that has 95K on it. I recently had front and rear rotors along with pads changed. I am now hearing a rubbing noise when I go into a turn or the road is bending. Any suggestion on what it could be? I checked the rotors to see if there are any scratches that could be a result of the rubbing but did not see anything. Could it be from the Lower ball joint?
Thanks
Old Oct 7, 2008 | 04:17 PM
Red Bully's Avatar
Red Bully
make sure after the brakes are done to seat them by doing high and low speed stops.
Old Oct 7, 2008 | 05:19 PM
shvc1991's Avatar
shvc1991
I doubt it's the lower ball joint, that would be more of a popping or clanking sound.
Try setting in the rotors and brakes. Just do as Red Bully says and do a series of high and low speed braking... Be a little hard on them too.
Old Oct 7, 2008 | 05:32 PM
GS FONZy's Avatar
GS FONZy
I've never had any issues that require to stop at high and low speeds to set rotors
What kind of rubbing noise? Tire, brakes, metal to metal, plastic, etc... There are many things that can cause rubbing, try and focus where the sound is coming from and what you think think it sound like, so we can try to help you. Also, please included any mods that you have done, if any.
Old Oct 7, 2008 | 05:36 PM
chuckb's Avatar
chuckb
people say aftermarket rear rotors will rub. search and you'll see more.
Old Oct 7, 2008 | 07:43 PM
GS FONZy's Avatar
GS FONZy
Can you quote your stament? I've never heard that before. I have aftermarket rotors my self and did not run into this or any problems.
Old Oct 7, 2008 | 08:09 PM
paradox's Avatar
paradox
Take a look at this posting and see if it reflects the issue you are experiencing:
https://www.clublexus.com/forums/sho...rotor+scraping
On post #8, the OP of that thread was able to provide a solution.
Old Oct 7, 2008 | 08:41 PM
chuckb's Avatar
chuckb
paradox already did, but here's another.
https://www.clublexus.com/forums/sho...ghlight=brembo
Originally Posted by DjFergi
I had the same issue when I replaced the OEM rotors.
Take a look at the backing plate behind the rotor. It is black in color and has a very small lip.
Flip your rotor around and look at the rotor hat. You should see a mark ground into the back of the rotor hat.
This is your grinding noise. To remedy it, you can remove that little backing plate or take a grinder and remove a few MM of the edge on the front of the lip on the backing plate.
I had to this this on both rear backing plates. No problems since.
Old Oct 7, 2008 | 09:53 PM
GS FONZy's Avatar
GS FONZy
Thanks
Old Oct 9, 2008 | 01:24 PM
ppgs400's Avatar
ppgs400
Thanks for all the great suggestions. The rotors were all after market bought from TireRack. The Rubbing noise only happens when I am going around a bend like a traffic circle. Driving on a straight road there are no noises.
Thanks
kings222
IS F (2008-2014)
30
Apr 19, 2023 01:00 PM
DCNASER
Aug 16, 2009 06:56 AM
FrankWhite
Sep 19, 2007 08:18 AM
kurtdog
Suspension and Brakes
Jan 7, 2002 07:36 AM
