Inside Dash problem REVISIT!
Old Sep 9, 2008 | 12:03 PM
sakataj's Avatar
sakataj
well i got a servo motor going bad think i might document a DIY on this if thats what the problem is..........sounds like yours is also
Old Sep 9, 2008 | 12:17 PM
jcat_350's Avatar
jcat_350
yeah man its the weirdest *****....it was buzzing on and off the whole time i drove at first, then constantly for about 20s when i first started it, now its doing a combination of the two.
if you could do a DIY that'd be dope. Idk if its the motor going bad or just needs grease, it's seen 7 years of heavy AC use in summers and heat use in the winters up here in New England.
Old Sep 9, 2008 | 03:11 PM
lexus ASM's Avatar
lexus ASM
Servo motors on the blower box, trying adjusting where the air comes out...
i.e dash vents, floor, defrost. If the noise happens then thats the servo motor you need to replace. if not try the hot cold, then listen for the same noise. also try the recirc. button, and again listne for the noise. once you have diagnosed the problem order the new servo motor and install.
The motors are located behind your glove box.
good luck.
JasotT
Jun 28, 2018 12:25 PM
Choosy
Aug 14, 2016 05:33 AM
mtnbound
RX - 3rd Gen (2010-2015)
Dec 28, 2015 05:44 AM
e-man
Feb 8, 2010 09:50 PM
LS_4Will
Mar 26, 2004 06:20 PM
