Upgrading Electrical System
Old Jul 2, 2008 | 02:47 PM
charmz's Avatar
charmz
Default Upgrading Electrical System
UPGRADE THE "BIG 3"
Anyone done this?
Upgrade to 2 Gauge Wire between:
1) alternator positive to battery positive
2) battery negative to chassis
3) engine ground to chassis
Is there a DIY anywhere I couldnt find it...
The reason I am looking into this is because I just got my audio system setup and it is drawing ALOT of power and causing my headlights/interior lights/guages/clock to dim on que with the bass!
I have seen other cars with a slight dim with aftermarket stereo's ...
BUT THIS IS OVER THE TOP!
Old Jul 3, 2008 | 12:56 AM
jjawaya's Avatar
jjawaya
there's two solutions to your problem that i know of. you can integrate a farad cap into you system. the size depends on how much power you're running. typically a 1 or a 1.5 should do it. also, you can upgrade your battery to a optima or something equivalant.
followthep
Apr 7, 2018 10:50 PM
mandyfig
Oct 14, 2013 02:19 AM
bklynjoker
Sep 28, 2012 09:14 AM
biglexass
May 16, 2006 07:06 PM
ryoj150
13
Mar 23, 2006 10:46 PM
